Insulation of Cooling Systems
Cooling systems and insulation thickness.
To avoid
  • heat gain and reduced efficiency of cooling systems
  • condensation of water on surfaces and potential corrosion problems
- pipes in cooling systems should always be insulated.
The insulation thickness of chilled water, refrigerant and brine systems should not be less than indicated below.
SystemOperation TemperaturePipe Size (inches)
< 1"1 1/4" - 2"2 1/2" - 4"5" - 6"> 8"
(oF)(oC)Insulation Thickness (inches)
Chilled Water 40 - 55 4 - 12 0.5 0.75 1.0 1.0 1.0
Refrigerant < 40 < 4 1.0 1.5 1.5 1.5 1.5
Brine < 40 < 4 1.0 1.5 1.5 1.5 1.5
  • 1 inch = 25.4 mm
Insulation of a cold system should be made with micro-cellular cross-linked polyethylene foam with low water vapor diffusion.
  • Insulation
  • The Engineering ToolBox (2005). Insulation of Cooling Systems. [online] Available at: https://www.engineeringtoolbox.com/insulation-cooling-system-d_899.html [Accessed Day Month Year].
