Angle Converter
Converting between angle units.
Angle Converter
Online angle units converter
Convert between angle units - degrees, radians, grades, minutes and more:
Converting between Degrees and Radians
Degrees are commonly used in "humans" language and radians are commonly used in computer languages. Since there is 360 degrees and 2 π radians in a circle
- degrees can be converted to radians with the equation
θ = 2 π Φ / 360                                         (1)
θ = radians
Φ = degrees
- and radians can be converted to degrees with the equation
Φ = 360 θ / (2 π)                                        (2)
Example - Converting between Degrees and Radians
90 degrees can be converted to radians with eq. (1) as
θ = 2 π (90) / 360
= 1.57 radians
1 radian can be converted to degrees with eq. (2) as
Φ = 360 (1) / (2 π)
= 57.3 degrees
Turns, Radians and Degrees
Turns vs. Radians vs. Degrees
TurnsRadiansDegrees
0 0 0
1/24 π/12 15
1/12 π/6 30
1/8 π/4 45
1/(2 π) 1 57.3..
1/6 π/3 60
1/4 π/2 90
1/3 2π/3 120
1/2 π 180
3/4 3π/2 270
1 360
  • Basics
  • Mathematics
  • The Engineering ToolBox (2003). Angle Converter. [online] Available at: https://www.engineeringtoolbox.com/angle-converter-d_1095.html [Accessed Day Month Year].
