ISA Instrumentation Codes used in Process Control Systems
The ISA standards and symbols are important for the P&IDs and documents describing the process control system.
Process VariableSymbolType of InstrumentSymbol
Analyses A Alarm A
Burner B Users Choice B
Combustion B Controller C
Users Choice C Control valve CV
Users Choice D Trap CV
Voltage V Sensor (primary element) E
Flow Rate F Rupture disc E
Users Choice G Sight or gage glass G
Current (electric) I Monitor G
Power J Indicator I
Time K Control Station K
Level L Light (pilot/operation) L
Users Choice M Users Choice N
Users Choice
N
Flow Resistance Orifice O
Users Choice O Test point (sample point) P
Pressure / Vacuum P Recorder R
Radiation R Switch S
Speed (or Frequency) S Transmitter T
Temperature T Multifunction U
Multivariable U Valve/Damper V
Vibration V Well W
Weight (force) W Unclassified X
Unclassified X Relay Y
Event Y Driver Z
Position, dimension Z Actuator Z
Example - ISA symbols for a Level Indicator
A level indicator will receive the symbol "L" for the process variable "Level", and "I" for the "Indicator" type of instrument. Both combines to:
LI
For unique identification within a system it is common to add a number to the ISA code, by example the code for level indicator no. eight may be:
LI 08
