Air humidity can be estimated by measuring
  • dry bulb temperature, and
  • wet bulb temperature
Humidity measurement - dry wet bulbe temperature meeter
Dry Bulb Temperature - Tdb - can be measured with a simple thermometer as shown above.
Wet Bulb Temperature - Twb - can be measured with a standard thermometer with some wet clothing, cotton or similar, around the bulb. Note that continuously air flow around the thermometer is important to evaporate water from the wet clothing and achieve a correct wet bulb temperature.
Sufficient air movement can be achieved with a sling thermometer or similar.
Relative humidity can be estimated from the tables below or alternatively from a psyhrometric or a Mollier diagram.
Example - The State of Air in the Mollier Diagram
If the dry bulb temperature of air is 19oC and the web bulb temperature is 12oC - then the state of air can be visualized in the Mollier diagram as indicated below.
  • the relative humidity is approximately 42%
  • the humidity ratio is approximately 0.0057 kgh2o/kgdry_air
Mollier diagram - state of air based on dry bulb and web bulb temperature
Relative Humidity - Temperature in Celsius
The table below can be used to estimate the relative humidity of air if dry and wet bulb temperatures are known.
Relative Humidity vs. Dry and Wet Bulb Temperatures - SI Units
Tdb - Twb
(oC)
Relative Humidity - RH (%)
Dry Bulb Temperature - Tdb (oC)
1518202225273033
1 90 91 91 92 92 92 93 93
2 80 82 83 84 85 85 86 87
3 71 73 75 76 77 78 79 80
4 62 65 67 68 70 71 73 74
5 53 57 59 61 64 65 67 69
6 44 49 52 54 57 59 61 63
7 36 42 45 47 51 53 55 58
8 28 34 38 41 45 47 50 53
9 21 27 31 34 39 41 45 48
10 13 20 25 28 33 36 40 43
Relative moisture - dry and wet bulb temperature diagram - degrees CelsiusDownload and print Air -  Relative Humidity vs. Dry and Wet Bulb Temperatures chart
Example - Relative Humidity
If the dry bulb temperature of air is 18oC and the web bulb temperature is 12oC - then the difference between them is 6oC. By using the table above
  • the relative humidity is approximately 49%
Example - the State of Air in the Psychrometric Chart
The state of air with dry bulb temperature 75oF and wet bulb temperature 62.5oF can be visualized in the psychrometric chart as indicated below.
  • the relative humidity is approximately 50%
  • the humidity ratio is approximately 65 grainsh2o/lbdry_air
Psychrometric chart - dry and wet bulb temperatures
Relative Humidity - Temperature in Fahrenheit
Relative Humidity vs. Dry and Wet Bulb Temperatures - Imperial Units
Tdb - Twb
(oF)
Dry Bulb Temperature - Tdb (oF)
6064687276808488
1 94 95 95 95 96 96 96 96
2 90 90 90 91 91 92 92 92
3 84 85 85 86 87 88 88 89
4 78 80 81 82 83 84 84 85
5 73 75 76 78 79 80 80 81
6 68 70 72 73 75 76 77 78
7 63 66 67 69 71 72 73 74
8 58 61 63 65 67 68 70 71
9 54 57 59 61 63 65 66 68
10 49 52 55 57 59 61 63 6
  • Air Conditioning Systems
  • Air Psychrometrics
  • Process Control Systems
    Instrumentation, design and documentation of process control systems.
  • The Engineering ToolBox (2003). Air - Humidity Measurement from Dry and Wet Bulb Temperature. [online] Available at: https://www.engineeringtoolbox.com/humidity-measurement-d_561.html [Accessed Day Month Year].
