Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Dry Bulb Temperature
Saturated Water Vapour
Heat Dry Air
Air Saturated with Water VaporWet Bulb Temperature
Pressure
Weight
Volume
Weight, GrainsHeat Content per lb. Dry Air and Vapor to Saturate It
(oF)(inches of Mercury)(Grains per Cu. Ft. of Vapor)(Grains per Pound of Dry Air)(Btu per lb above 0oF)(Cu. Ft of 1 lb dry Air and Vapor to saturate it)(Dry Air in 1 Cu. Ft. of Mixture)(Air and Vapor in 1 Cu. Ft. of Mixture)(Heat of Vapor Above 32oF)(Total Enthaply Btu)(oF)
-40 0.0039 0.054 0.569 -9.60 10.58 661.4 661.5 0.085 -9.515 -40
-30 0.0069 0.093 1.004 -7.20 10.84 646.1 646.2 0.150 -7.050 -30
-20 0.0126 0.165 1.834 -4.80 11.09 631.3 631.5 0.276 -4.524 -20
-10 0.0222 0.285 3.233 -2.40 11.34 617.2 617.5 0.488 -1.920 -10
0 0.0383 0.481 5.58 0.00 11.60 603.2 603.7 0.846 0.846 0
10 0.0631 0.775 9.19 2.40 11.86 590.4 591.1 1.40 3.799 10
20 0.103 1.239 15.04 4.80 12.14 576.8 578.0 2.30 7.099 20
30 0.164 1.933 23.99 7.20 12.41 563.9 565.9 3.68 10.88 30
40 0.2478 2.864 36.36 9.60 12.69 551.4 554.3 5.61 15.21 40
50 0.3626 4.110 53.41 12.00 13.00 538.7 542.8 8.27 20.27 50
60 0.5218 5.801 77.27 14.40 13.32 524.5 531.3 12.01 26.41 60
70 0.7392 8.065 110.28 16.80 13.67 511.9 520.0 17.21 34.01 70
80 1.0321 11.06 155.52 19.20 14.07 497.7 508.7 24.37 43.57 80
90 1.4215 14.96 217.13 21.60 14.52 482.2 497.2 34.15 55.75 90
100 1.9325 19.98 300.60 24.00 15.05 465.2 485.2 47.46 71.46 100
110 2.5955 26.38 413.50 26.40 15.68 446.5 472.9 65.54 91.94 110
120 3.4458 34.44 566.67 28.80 16.46 425.4 456.8 90.16 118.96 120
130 4.5251 44.49 775.80 31.20 17.44 401.4 445.9 123.90 155.10 130
140 5.8812 56.91 1065.1 33.60 18.71 374.1 431.0 170.72 204.32 140
150 7.569 72.11 1474.3 36.00 20.44 342.5 414.6 237.17 273.17 150
160 9.652 90.57 2073.2 38.40 22.89 305.8 396.4 334.73 373.13 160
170 12.199 112.79 2996.9 40.80 26.57 263.5 376.2 485.59 526.39 170
180 15.291 139.36 4550.4 43.20 32.65 214.4 353.7 739.81 783.01 180
190 19.014 170.90 7589.5 45.60 44.41 157.6 328.5 1237.93 1283.53 190
200 23.467 208.09 15828.9 48.00 76.07 92.0 300.1 2591.88 2638.88 200
  • Air Psychrometrics
  • The Engineering ToolBox (2010). Moist Air - Psychrometric Table for Pressure 29.92 inHg. [online] Available at: https://www.engineeringtoolbox.com/air-psychrometric-table-d_1574.html [Accessed Day Month Year].
