District Heating - Heat Capacity vs. Temperature
Water temperature and heating capacity.
An increase in the hot water supply temperature will reduce the volume flow in a district heating system where the required heat is constant.
Supply Temperature
(oC)
Required Water Flow
(liters/kW)
90 28.7
100 21.5
112 16.4
120 14.3
133 11.8
150 9.6
180 7.2
  • based on 60 oC return temperature
  • Heating Systems
  • The Engineering ToolBox (2011). District Heating - Heat Capacity vs. Temperature. [online] Available at: https://www.engineeringtoolbox.com/district-heating-temperature-capacity-d_1810.html [Accessed Day Month Year].
