Hot-Water Heating Systems - Classification
Hot-water heating systems can be classified by temperature and pressure.
Hot-water systems can be classified by operating temperature into three groups
  • low temperature - LTW
  • medium temperature - MTW
  • high temperature - HTW
Low Temperature Hot-Water Heating System - LTW
  • operates within a temperature of 250 oF (121 oC). The maximum allowable working pressure for a LTW system is usual 30 psi (2 bar).
  • LTW systems are in general used for space heating in homes, residential buildings, offices, local distribution of district heating systems and similar.
Medium Temperature Hot-Water Heating System - MTW
  • MTW systems operates at a temperature of 350 oF (177 oC) or less. The maximum allowable working pressure for a MTW system is usual 150 psi (10.5 bar)
  • MTW systems are often used in large hot-water distribution systems like district heating, and in systems where process applications requires higher temperatures than achievable by LTW systems
High Temperature Hot-Water Heating System - HTW
  • HTW systems operates at temperatures exceeding 350 oF (177 oC) or more. The maximum operating pressure for a HTW system is usual less than 300 psi (20.7 bar).
  • HTW systems are used like MTW systems in large distribution and process application systems.
