Radiators - Heat Emission
Calculate heat emission from column and panel radiators.
Heat output from a radiator is determined by the
  • ambient surrounding temperature
  • temperature of the radiator surface
  • surface area of the radiator
The formulas below can be used to estimate the heat emission from radiators where the temperature difference between the radiator surface and the ambient air is 50 oC (inlet water temperature 80 oC, outlet water temperature 60 oC and ambient air 20 oC).
Heat Emission from Column Radiators
column radiator heat emission
The heat emission from a column radiator can roughly be estimated as
P = kc Ve                                            (1)
P = heat emission (W)
kc = 15000 - 17000 - constant for column radiator
Ve = external radiator volume (m3)
Heat Emission from Panel Radiators
panel radiator heat emission
The heat emission from a panel radiator can roughly be estimated as
P = 41 kp l (1 + 8 h)                                    (2)
kp = constant for panel radiator
l = radiator length (m)
h = radiator height (m)
Typical panel radiator configuration constants - kp:
  • 3.1 : for a  single panel
  • 4.1 : for a panel - convector
  • 4.9 : for two panels
  • 5.8 : for a panel - convector - panel
  • 7 : for a panel - convector - convector - panel
  • 7.6 : for three panels
  • 8.8 : for a panel - convector - panel - convector - panel
  • 9 : for four panels
Panel Radiator Calculator
