The Engineering ToolBox Web Google
Piping Systems - Dimensions
Sizes and dimensions of pipes and tubes, and their fittings - inside and outside diameter, weight and more
American Standard Straight Pipe
Pipe diameter - threads and tap drill
ASTM B 280 Copper Tube - ACR
Standard Specification for Seamless Copper Tube for Air Conditioning and Refrigeration Field Service - ACR
B.W.G. - Birmingham Wire Gauge
The wall thickness of pipes - Gauge and decimal parts of an inch
Bolt Stretching
Bolt stretch according Hooke's Law
Briggs Standard Pipe Taps - Drill Sizes
Drill sizes for Briggs Standard Pipe taps
Calculating Pipes Weight
A weight calculating formula for steel pipes
Capacities of Threaded Steel Rods
Capacities of threaded steel rods used as hangers in piping systems
Carbon and Stainless Steel Welding Neck Flange Bores
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings
Carbon, Alloy and Stainless Steel Pipes - ASME/ANSI B36.10/19
Pipe sizes, inside and outside diameters, wall thickness, schedules, moment of inertia, transverse area, weight of pipe filled with water - U.S. Customary Units
Pipe sizes, inside and outside diameters, wall thickness, schedules, weight and weight of pipe filled with water - Metric Units
Cleanouts
Cleanouts provides access to the sewer for rodding
Commercial Pipe - Properties
Properties of commercial pipe - metric data
Content of Horizontal Cylindrical Tanks
Volume of horizontal cylindrical tanks at different levels - online calculator
Copper Tubes - ASTM B88
Copper Water and Gas Tube according ASTM B 88 - imperial units
Copper Tubes - ASTM B88M
Copper Water and Gas Tube according ASTM B 88M - metric units
Copper Tubes DWV - Drain, Waste and Vent
Dimensions of copper tube ASTM 306 DWV - Drain Waste and Vent
Copper Tubes to BS (British Standard) 2871 - Dimensions and Working Pressures
Metric Sizes of copper tubes to BS (British Standard) 2871:1972
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes dimensions 1/4" to 12"
CPVC Pipes - Support Spacing
Support spacing for CPVC pipes
Difference between Pipes and Tubes
Pipes and tubes are not the same
Dimensions Butt-Welding Fittings
Butt-Welding Fittings - B16.9 - dimensions
Epoxy Pipes - Support Spacing
Support spacing for reinforced Epoxy fiberglass pipes
Equation of Continuity
The Equation of Continuity is a statement of mass conservation
Fiberglass Pipes - Temperature Limits
Temperature range for fiberglass Epoxy, Furan, Phenolic, Polyester and Vinyl Ester pipes
Flanges - API vs. ASME/ANSI
Comparing API and ASME/ANSI flanges
Flanges and Bolt Dimensions - 150 lb to 2500 lb - ASME/ANSI B16.5
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - 150 psi to 2500 psi
Forged Steel Flanges - Stud Reference Charts
The number, diameter and length of studs for ANSI forged steel flanges 150 lb, 300 lb, 400 lb, 600lb, 900 lb and 1500 lb
Hanger Rods and Load Capacity
Load ratings for threaded hanger rods
Hanger Spacing and Rod Size for Horizontal Pipes
Recommended maximum span between hangers - and rod sizes for straight horizontal pipes
Hot Bending - Copper and Copper Alloy Pipe
Temperature range for bending copper pipe and tube
Hot Bending - Nickel and Nickel Alloy Pipe
Temperature range for bending nickel and nickel alloy pipe and tube
Identification Tests for Stainless Steels
Magnetic, spark, hardness and acid identification tests of austenitic, martensitic and ferritic stainless steels
Inches and Decimal Equivalents
Decimal equivalents of eights, sixteenths, thirty-seconds and sixty-fourths of an inch
Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out
Nominal Wall Thickness Pipe
Nominal wall thickness seamless and welded carbon and alloy steel pipes
NPS - "Nominal Pipe Size" and DN - "Diametre Nominal"
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - "Diametre Nominel"
NPT- National Pipe Thread Taper- ANSI B1.20.1
NPT pipe threads - dimensions according ANSI/ASME B1.20.1
PE Pipes and Dimensions
PE pipe dimensions according European Standards
PE Pipes and Pressure Grades
Polyethylene - PE - pipes and pressure classes
PE Pipes and Weights
Weight of PE pipes
Pipe Equations
Calculate cross-sectional area, weight of empty pipes, weight of pipes filled with water, inside and outside surface area
Pipe Flanges and Gasket Dimensions
Gasket dimensions for pipe flanges and flange fittings ASME B16.5 Pipe Flanges and Flange Fittings
Pipe Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Pipe Lengths
Pipe is supplied and refered to as single random, double random and cut lengths
Drill sizes for British Whitworth Standard and Briggs American Standard pipe taps
Pipe Threads for Tubes and Fittings where Pressuretight joints are made on the Threads - BS 21
BSPT - British Standard Pipe Taper threads & BSP or BSPF - British Standard Pipe Parallel (Straight) threads
Pipe Threads where Pressuretight Joints are made on the Threads - ISO 7-1
ISO 7-1:1994 Pipe threads where pressure-tight joints are made on the threads
Piping - Bundling Schedule
Bundling schedule - Standard Weight and Extra Strong Pipe
Polypropylene PP - Chemical Resistance
Chemical resistance of PolyPropylene - PP - to some common acids, bases, organic substances and solvents
PP Pipes - Support Spacing
Hanger spacing for PolyPropylene pipes
Pressfit Pipes Dimensions
Dimension of pressfit pipes
PVC and CPVC Pipes - Schedule 40 & 80
Standard dimensions and weight of PVC - Polyvinyl Chloride - and CPVC - Chlorinated Polyvinyl Chloride - pipes according ASTM D1785
Support spacing for PVC pipes
PVC Sewer & Drain Pipe
Dimensions of PVC sewer & drain pipe
PVDF Pipes - Support Spacing
Support spacing for PVDF pipes
Schedule Terminology
An introduction to pipes and the schedule terminology
Schedule Thickness of Pipes
Introduction to the schedule, standard wall - STD, extra strong wall - XS - and double extra strong wall - XXS terminology
Stainless Steel Pipes - Dimensions and Weights ANSI/ASME 36.19
Dimensions, wall thickness and weights of stainless steel pipes according to ASME B36.19 Stainless Steel Pipe
Stainless Steel Weld Fittings - Dimensions ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19
Steel Pipe Reference Chart
Confused about ANSI pipe schedules in inches and wall thickness? Use the following ANSI pipe dimension and weight chart!
Steel Pipes and Weights
Weight of steel pipes and tubing
Steel Pipework Support
Recommended support of steel pipes
Steel Tubes BS 1387 (EN 10255)
Dimensions and weights of steel tubes according BSi - BS 1387:1985 (EN 10255) Specification for screwed and socketed steel tubes and tubulars and for plain end steel tubes suitable for welding or for screwing to BS 21 pipe threads
Stud Reference Charts for Cast Iron Flanges
The number, diameter and length of studs for cast iron flanges class 125 and 250
Support Copper Pipework
Recommended support of copper tubes
Support Spacing for PVC, Fiberglass and Steel Pipes
Support span for Fiberglass, PVC and Steel pipes
Supporting Pressfit Pipes
Maximum span between supports of pressfit pipes
Thread Standards - Piping
Piping thread standards
Thread Standards Used for Piping and Fluid Connectors
Thread designations and standards for threads used in piping and fluid connectors
Weight of Welded Steel Pipes
Nominal weight of welded steel pipes ranging 26 - 60 inches
Search the ToolBox
9 12 8
handheld Engineering ToolBox - optimized for mobile devices! 3D Engineering ToolBox - draw and model technical applications!
Resources, Tools and Basic Information  for Engineering and Design of Technical Applications!
