Steel Pipes - Supports
Recommended max. distance between steel pipe supports.
Support Spacing in Meter
Steel Pipes - Supports - Metric Units
Outside Diameter
(mm)
Steel Pipe - Distance between Supports (m)
Horizontal RunVertical Run
15 1.5 3.0
20 2.4 3.0
25 2.4 3.0
32 2.4 3.7
40 2.4 3.7
50 2.4 4.6
65 3.0 4.6
80 3.0 4.6
100 3.0 5.5
Support Spacing in Feet
Steel Pipes - Supports - Imperial Units
Nominal Pipe Size
(in)
Support Spacing
(ft)
1 7
1 1/2 9
2 10
3 12
4 14
6 17
8 19
10 22
  • The Engineering ToolBox (2008). Steel Pipes - Supports. [online] Available at: https://www.engineeringtoolbox.com/steel-pipe-supports-d_1071.html [Accessed Day Month Year].
