Stainless steel pipes are used in constructions, food industry, pharmaceutical industry, petrochemical industry, automotive industry, municipal and decorative purposes.
Range of Stainless Steel pipes according to ANSI/ASME 36.19M - Stainless Steel Pipe.
For full table with Schedule 80S - rotate the screen!
Nominal
Pipe
Size
(inches)
Outside
Diameter
Schedule
5S10S40S80S
(mm)(inches)Wall Thickness and Weight
mm
(in)
kg/mmm
(in)
kg/mmm
(in)
kg/mmm
(in)
kg/m
1/8 10.3 0.405 - - 1.25
(0.049)
0.28 1.73
(0.068)
0.37 2.42
(0.095)
0.47
1/4 13.7 0.540 - - 1.66
(0.065)
0.49 2.24
(0.088)
0.63 3.03
(0.119)
0.80
3/8 17.2 0.675 - - 1.66
(0.065)
0.63 2.32
(0.091)
0.85 3.20
(0.126)
1.10
1/2 21.3 0.840 1.65
(0.065)
0.81 2.11
(0.083)
1.00 2.77
(0.109)
1.27 3.74
(0.147)
1.62
3/4 26.7 1.050 1.65
(0.065)
1.02 2.11
(0.083)
1.28 2.87
(0.113)
1.68 3.92
(0.154)
2.20
1 33.4 1.315 1.65
(0.065)
1.30 2.77
(0.109)
2.09 3.38
(0.133)
2.50 4.55
(0.179)
3.24
1 1/4 42.2 1.660 1.65
(0.065)
1.66 2.77
(0.109)
2.69 3.56
(0.140)
3.39 4.86
(0.191)
4.47
1 1/2 48.3 1.900 1.65
(0.065)
1.91 2.77
(0.109)
3.11 3.69
(0.145)
4.06 5.08
(0.200)
5.41
2 60.3 2.375 1.65
(0.065)
2.40 2.77
(0.109)
3.93 3.92
(0.154)
5.45 5.54
(0.218)
7.49
2 1/2 73.0 2.875 2.11
(0.083)
3.69 3.05
(0.120)
5.26 5.16
(0.203)
8.64 7.01
(0.276)
11.4
3 88.9 3.500 2.11
(0.083)
4.52 3.05
(0.120)
6.46 5.49
(0.216)
11.3 7.62
(0.300)
15.3
3 1/2 101.6 4.000 2.11
(0.083)
5.18 3.05
(0.120)
7.41 5.74
(0.226)
13.6 8.08
(0.318)
18.6
4 114.3 4.500 2.11
(0.083)
5.84 3.05
(0.120)
8.37 6.02
(0.237)
16.1 8.56
(0.337)
22.3
5 141.3 5.563 2.77
(0.109)
9.46 3.41
(0.134)
11.6 6.56
(0.258)
21.8 9.53
(0.375)
31.0
6 168.3 6.625 2.77
(0.109)
11.3 3.41
(0.134)
13.9 7.12
(0.280)
28.3 10.98
(0.432)
42.6
8 219.1 8.625 2.77
(0.109)
14.8 3.76
(0.148)
20.0 8.18
(0.322)
42.5 12.70
(0.500)
64.6
10 273.1 10.750 3.41
(0.134)
22.7 4.20
(0.165)
27.8 9.28
(0.365)
60.4 12.70
(0.500)
81.5
12 323.9 12.750 3.97
(0.156)
31.3 4.58
(0.180)
36.1 9.53
(0.375)
73.9 12.70
(0.500)
97.4
  • Piping Systems
  • The Engineering ToolBox (2003). Stainless Steel Pipes - Dimensions and Weights. [online] Available at: https://www.engineeringtoolbox.com/ansi-stainless-steel-pipes-d_247.html [Accessed Day Month Year].
