ANSI Schedule 80 Steel Pipes - Dimensions
Based on ASTM A53 - Standard Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless.
For full table with Length vs. External and Internal Surface, Volume, Weight and Number of Threads - rotate the screen!
Pipe Size
(in)
Diameter
(in)
Nominal Thickness
(in)
Transverse Areas
(in2)
Length of Pipe
(per sq. foot of)
Volume
(ft3/ft)
WeightNumber of Threads per inch of Screw
ExternalInternalExternalInternalSteelExternal Surface
(ft)
Internal Surface (ft)lb/ftkg/m
1/8 0.41 0.22 0.10 0.13 0.04 0.09 9.43 17.75 0.0003 0.31 0.47 27
¼ 0.54 0.30 0.12 0.23 0.07 0.16 7.07 12.65 0.0005 0.54 0.80 18
3/8 0.68 0.42 0.13 0.36 0.14 0.22 5.66 9.03 0.0010 0.74 1.10 18
½ 0.84 0.55 0.15 0.55 0.23 0.32 4.55 7.00 0.0016 1.00 1.49 14
¾ 1.05 0.74 0.15 0.87 0.43 0.43 3.64 5.15 0.0030 1.47 2.19 14
1 1.32 0.96 0.18 1.36 0.72 0.64 2.90 4.00 0.0050 2.17 3.23 11 ½
1 ¼ 1.66 1.28 0.19 2.16 1.28 0.88 2.30 2.99 0.0089 3.00 4.46 11 ½
1 ½ 1.90 1.50 0.20 2.84 1.77 1.07 2.01 2.54 0.0123 3.65 5.43 11 ½
2 2.38 1.94 0.22 4.43 2.95 1.48 1.61 1.97 0.0205 5.02 7.47 11 ½
2 ½ 2.88 2.32 0.28 6.49 4.24 2.25 1.33 1.65 0.0294 7.66 11.40 8
3 3.50 2.90 0.30 9.62 6.61 3.02 1.09 1.32 0.0459 10.30 15.33 8
3 ½ 4.00 3.36 0.32 12.56 8.89 3.68 0.95 1.14 0.0617 12.50 18.60 8
4 4.50 3.83 0.34 15.90 11.50 4.41 0.85 1.00 0.08 14.90 22.17 8
5 5.56 4.81 0.38 24.30 18.19 6.11 0.69 0.79 0.1263 20.80 30.95 8
6 6.63 5.76 0.43 34.47 26.07 8.30 0.58 0.67 0.1810 28.60 42.56 8
8 8.63 7.63 0.50 58.42 45.66 12.76 0.44 0.50 0.3171 43.40 64.59 8
10 10.75 9.56 0.59 90.76 71.84 18.92 0.36 0.40 0.4989 64.40 95.84 8
12 12.75 11.38 0.69 127.64 101.64 26.00 0.30 0.34 0.7058 88.60 131.85
14 14.00 12.50 0.75 153.94 122.72 31.22 0.27 0.31 0.8522 107.00 159.23
16 16.00 14.31 0.84 201.05 160.92 40.13 0.24 0.26 1.1170 137.00 203.88
18 18.00 16.13 0.94 254.85 204.24 50.61 0.21 0.24 1.4180 171.00 254.48
20 20.00 17.94 1.03 314.15 252.72 61.43 0.19 0.21 1.7550 209.00 311.03
24 24.00 21.56 1.22 452.40 365.22 87.18 0.16 0.17 2.5360 297.00 441.99
ASTM A53 pipe  - also referred to as ASME SA53 pipe - is intended for mechanical and pressure applications. Can be used in steam, water, gas and air lines. Suitable for welding and forming like coiling, bending and flanging.
  • 1 in2 = 645.2 mm2 = 6.452 cm2 = 6.452x10-4 m2
  • 1 ft (foot) = 0.3048 m
  • Piping Codes and Standards
  • Piping Systems
  • The Engineering ToolBox (2003). ANSI Schedule 80 Steel Pipes - Dimensions . [online] Available at: https://www.engineeringtoolbox.com/ansi-steel-pipes-d_306.html [Accessed Day Month Year].
