Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules
Pressure classes, schedules and weights of pipes for threaded & socket welded fittings.
Pipe Schedule and Designation
Pressure Class2000300060009000
Threaded Fittings 80/XS 160 XXS
Socket-welded Fittings   80/XS 160 XXS
  • Standard (STD), Extra Strong (XS) and Double Extra Strong (XXS)
  • Schedule - numbers assigned to different wall thickness of pipe (i.e. schedule 80)
Threaded fittings are available in pressure classes 2000, 3000 and 6000.
Socket-welded fittings are available in pressure classes 3000, 6000 and 9000.
  • Piping Codes and Standards
  • Piping Systems
  • The Engineering ToolBox (2003). Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules. [online] Available at: https://www.engineeringtoolbox.com/threaded-socket-welded-fittings-d_33.html [Accessed Day Month Year].
