ISO - Pipe, Tube and Fittings Standards and Specifications
International Organization for Standardization - ISO - pipe, tube and fittings standards and specifications.
Industrial pipe, tube and fittings standards and specifications from the ISO - International Organization for Standardization:
  • ISO 7-1:1994-05
    Pipe threads where pressure-tight joints are made on the threads - Part 1: Dimensions, tolerances and designation
  • ISO 7-2:2000
    Pipe threads where pressure-tight joints are made on the threads - Part 2: Verification by means of limit gauges
  • ISO 49:1994
    Malleable cast iron fittings threaded to ISO 7-1
  • ISO 228-1:2000
    Pipe threads where pressure-tight joints are not made on the threads - Part 1: Dimensions, tolerances and designation
  • ISO 228-2:1987
    Pipe threads where pressure-tight joints are not made on the threads; Part 2 : Verification by means of limit gauges
  • ISO 264:1976
    Unplasticized polyvinyl chloride (PVC) fittings with plain sockets for pipes under pressure; Laying lengths; Metric series
  • ISO 265-1:1988
    Pipes and fittings of plastics materials; fittings for domestic and industrial waste pipes; basic dimensions: metric series; part 1: unplasticized poly(vinyl chloride) (PVC-U)
  • ISO 392:1986
    Asbestos-cement pipe fittings for building and sanitary purposes
  • ISO 580:1990
    Injection-molded unplasticized poly(vinyl chloride) (PVC-U) fittings; oven test; test method and basic specifications
  • ISO 727-1:2002
    Fittings made from unplasticized poly(vinyl chloride) (PVC-U), chlorinated poly(vinyl chloride) (PVC-C) or acrylonitrile/butadiene/styrene (ABS) with plain sockets for pipes under pressure - Part 1: Metric series
  • ISO 727-2:2002
    Fittings made from unplasticized poly(vinyl chloride) (PVC-U), chlorinated poly(vinyl chloride) (PVC-C) or acrylonitrile/butadiene/styrene (ABS) with plain sockets for pipes under pressure - Part 2: Inch-based series
  • ISO 881:1980
    Asbestos-cement pipes, joints, fittings/sewage/drain
  • ISO 1179:1981
    Pipe connections, threaded to ISO 228/1, for plain end steel and other metal tubes in industrial applications
  • ISO 1635-2:1987
    Seamless wrought copper and copper alloy tube
  • ISO 1651:1974
    Tube drawing mandrels
  • ISO 1684:1975
    Wire, bar and tube drawing dies; Specifications
  • ISO 2016:1981
    Capillary solder fittings for copper tubes; Assembly dimensions and tests
  • ISO 2035:1974
    Unplasticized polyvinyl chloride (PVC) moulded fittings for elastic sealing ring type joints for use under pressure; Pressure-resistance test
  • ISO 2044:1974
    Unplasticized polyvinyl chloride (PVC) injection-moulded solvent-welded socket fittings for use with pressure pipe; Hydraulic internal pressure test
  • ISO 2048:1990
    Double-socket fittings for unplasticized poly(vinyl chloride) (PVC-U) pressure pipes with elastic sealing ring type joints; minimum depths of engagement
  • ISO 2284:1987
    Hand taps for parallel and taper pipe threads; General dimensions and marking
  • ISO 2507-1:1995
    Thermoplastics pipes and fittings - Vicat softening temperature - Part 1: General test method
  • ISO 2507-2:1995
    Thermoplastics pipes and fittings - Vicat softening temperature - Part 2: Test conditions for unplasticized poly(vinyl chloride) (PVC-U) or chlorinated poly(vinyl chloride) (PVC-C) pipes and fittings and for high impact resistance poly(vinyl chloride) (PVC-HI) pipes
  • ISO 2507-3:1995
    Thermoplastics pipes and fittings - Vicat softening temperature - Part 3: Test conditions for acrylonitrile/butadiene/styrene (ABS) and acrylonitrile/styrene/acrylic ester (ASA) pipes and fittings
  • ISO 2531:1998
    Ductile iron pipes, fittings, accessories and their joints for water or gas applications
  • ISO 2804:1996
    Wire, bar or tube drawing dies - As-sintered pellets of hardmetal (carbide) - Dimensions
  • ISO 2851:1993
    Stainless steel bends and tees for the food industry
  • ISO 2852:1993
    Stainless steel clamp pipe couplings for the food industry
  • ISO 3183-1:1996
    Petroleum and natural gas industries - Steel pipe for pipelines - Technical delivery conditions - Part 1: Pipes of requirement class A
  • ISO 3183-2:1996
    Petroleum and natural gas industries - Steel pipe for pipelines - Technical delivery conditions - Part 2: Pipes of requirements class B
  • ISO 3253:1998
    Gas welding equipment - Hose connections for equipment for welding, cutting and allied processes
  • ISO/TR 3313:1998
    Measurement of fluid flow in closed conduits - Guidelines on the effects of flow pulsations on flow-measurement instruments
  • ISO 3419:1981
    Non-alloy and alloy steel butt-welding fittings
  • ISO 3458:1976
    Assembled joints between fittings and polyethylene (PE) pressure pipes ; Test of leakproofness under internal pressure
  • ISO 3459:1976
    Polyethylene (PE) pressure pipes; Joints assembled with mechanical fittings; Internal under-pressure test method and requirement
  • ISO 3477:1981
    Polypropylene (PP) pipes and fittings - density
  • ISO 3501:1976
    Assembled joints between fittings and polyethylene (PE) pressure pipes; Test of resistance to pull out
  • ISO 3503:1976
    Assembled joints between fittings and polyethylene (PE) pressure pipes; Test of leakproofness under internal pressure when subjected to bending
  • ISO 3514:1976
    Chlorinated polyvinyl chloride (CPVC) pipes and fittings; Specification and determination of density
  • ISO 3545-1:1989
    Steel tubes and fittings; symbols for use in specifications; part 1: tubes and tubular accessories with circular cross-section
  • ISO 3545-2:1989
    Steel tubes and fittings; symbols for use in specifications; part 2: square and rectangular hollow sections
  • ISO 3545-3:1989
    Steel tubes and fittings; symbols for use in specifications; part 3: tubular fittings with circular cross-section
  • ISO 3586:1976
    Glass plant, pipeline and fittings; general rules for testing, handling and use
  • ISO 3587:1976
    Glass plant, pipeline and fittings; Pipeline and fittings of nominal bore 15 to 150 mm; Compatibility and interchangeability
  • ISO 3603:1977
    Fittings for unplasticized polyvinyl chloride (PVC) pressure pipes with elastic sealing ring type joints; Pressure test for leakproofness
  • ISO 3604:1976
    Fittings for unplasticized polyvinyl chloride (PVC) pressure pipes with elastic sealing ring type joints; Pressure test for leakproofness under conditions of external hydraulic pressure
  • ISO 3633:2002
    Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Unplasticized poly(vinyl chloride) (PVC-U)
  • ISO 4056:1978
    Polyethylene (PE) pipes and fittings- designation
  • ISO 4059:1978
    Polyethylene (PE) pipes; Pressure drop in mechanical pipe-jointing systems; Method of test and requirements
  • ISO 4132:1979
    Unplasticized polyvinyl chloride (PVC) and metal adaptor fittings for pipes under pressure; Laying lengths and size of threads; Metric series
  • ISO 4144:2003
    Pipework - Stainless steel fittings threaded in accordance with ISO 7-1
  • ISO 4145:1986
    Non-alloy steel fittings threaded to ISO 7/1
  • ISO 4230:1987
    Hand- and machine-operated circular screwing dies for taper pipe threads; R series
  • ISO 4231:1987
    Hand- and machine-operated circular screwing dies for parallel pipe threads - G series
  • ISO 4397:1993
    Fluid power systems and components; connectors and associated components; nominal outside diameters of tubes and nominal inside diameters of hoses
  • ISO 4439:1979
    Unplasticized polyvinyl chloride (PVC) pipes and fittings; Determination and specification of density
  • ISO 4422-1:1996
    Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 1: General
  • ISO 4422-2:1996
    Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 2: Pipes (with or without integral sockets)
  • ISO 4422-3:1996
    Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 3: Fittings and joints
  • ISO 4422-5:1997
    Pipes and fittings made of unplasticized poly(vinyl chloride) (PVC-U) for water supply - Specifications - Part 5: Fitness for purpose of the system
  • ISO 4435:2003
    Plastics piping systems for non-pressure underground drainage and sewerage - Unplasticized poly(vinyl chloride) (PVC-U)
  • ISO 4440-1:1994
    Thermoplastics pipes and fittings - Determination of melt mass-flow rate - Part 1: Test method
  • ISO 4440-2:1994
    Thermoplastics pipes and fittings - Determination of melt mass-flow rate - Part 2: Test conditions
  • ISO 4451:1980
    Polyethylene (PE) pipes and fittings - determinati
  • ISO 4483:1979
    Asbestos-cement pipelines; Field pressure testing
  • ISO 4486:1985
    Asbestos-cement ventilation ducts and fittings; Dimensions and characteristics
  • ISO 4488:1979
    Asbestos-cement pipes and joints for thrust-boring and pipe jacking
  • ISO 4704:1977
    Glass plant, pipeline and fittings; Glass plant components
  • ISO/TR 5168:1998
    Measurement of fluid flow - Evaluation of uncertainties
  • ISO 5251:1981
    Stainless steel butt-welding fittings
  • ISO 5256:1985
    Steel pipes and fittings for buried or submerged pipe lines; External and internal coating by bitumen or coal tar derived materials
  • ISO 5361:1999
    Anaesthetic and respiratory equipment - Tracheal tubes and connectors
  • ISO 5730:1992
    Stationary shell boilers of welded construction (other than water-tube boilers)
  • ISO 5969:1979
    Ground thread taps for pipe threads G series and Rp series; Tolerances on the threaded portion
  • ISO 6207:1992
    Seamless nickel and nickel alloy tube
  • ISO 6447:1983
    Rubber seals; Joint rings used for gas supply pipes and fittings; Specification for material
  • ISO 6448:1985
    Rubber seals; Joint rings used for petroleum product supply pipes and fittings; Specification for material
  • ISO 6455:1983
    Unplasticized polyvinyl chloride (PVC) fittings with elastic sealing ring type joints for pipes under pressure; Dimensions of laying lengths; Metric series
  • ISO 6594:1983
    Cast iron drainage pipes and fittings; Spigot series
  • ISO 6605:2002
    Hydraulic fluid power - Hoses and hose assemblies - Test methods
  • ISO 6761:1981
    Steel tubes; Preparation of ends of tubes and fittings for welding
  • ISO 6964:1986
    Polyolefin pipes and fittings; Determination of carbon black content by calcination and pyrolysis; Test method and basic specification
  • ISO/TR 7074:1986
    Performance requirements for plastics pipes and fittings for use in underground drainage and sewage
  • ISO 7228:1993
    Tracheal tube connectors
  • ISO 7245:1984
    Pipes and fittings of acrylonitrile-butadiene- styrene (ABS); General specification for moulding and extrusion materials
  • ISO 7246:1984
    Pipes and fittings of acrylonitrile/styrene/ acrylester (ASA); General specification for moulding and extrusion materials
  • ISO 7268:1983
    Pipe components; Definition of nominal pressure
  • ISO 7278-2:1988
    Liquid hydrocarbons; dynamic measurement; proving systems for volumetric meters;
    part 2: pipe provers
  • ISO 7279:1984
    Polypropylene (PP) fittings for pipes under pressure; Sockets for fusion using heated tools; Metric series; Dimensions of sockets
  • ISO 7370:1982
    Glass fibre reinforced thermosetting plastics (GRP) pipes and fittings; Nominal diameters, specified diameters and standard lengths
  • ISO 7387-1:1983
    Adhesives with solvents for assembly of u PVC pipe elements; Characterization; Part 1 : Basic test methods
  • ISO 7608:1985
    Shipbuilding; Inland navigation; Couplings for disposal of oily mixture and sewage water
  • ISO 7671:2003
    Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Polypropylene (PP)
  • ISO 7675:2003
    Plastic piping systems for soil and waste discharge (low and high temperature) inside buildings - Chlorinated poly(vinyl chloride) (PVC-C)
  • ISO 7682:2003
    Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Acrylonitrile-butadiene-styrene (ABS)
  • ISO 7686:1992
    Plastics pipes and fittings; opacity; test method
  • ISO 8142:1990
    Thermal insulation; bonded preformed man-made mineral fiber pipe sections; specification
  • ISO 8283-1:1991
    Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 1: unplasticized poly(vinyl chloride) (PVC-U) and chlorinated poly(vinyl chloride) (PVC-C)
  • ISO 8283-2:1992
    Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 2: polyethylene (PE)
  • ISO 8283-3:1992
    Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 3: polypropylene (PP)
  • ISO 8283-4:1992
    Plastics pipes and fittings; dimensions of sockets and spigots for discharge systems inside buildings; part 4: acrylonitrile/butadiene/styrene (ABS)
  • ISO 8361-1:1991
    Thermoplastics pipes and fittings; water absorption;
    part 1: general test method
  • ISO 8361-2:1991
    part 2: test conditions for unplasticized poly(vinyl chloride) (PVC-U) pipes and fittings
  • ISO 8361-3:1991
    part 3: test conditions for acrylonitrile/butadiene/styrene (ABS) pipes and fittings
  • ISO 8434-1, :1994
    Metallic tube connections for fluid power and general use -
    Part 1: 24 compression fittings
  • ISO 8434-2:1994
    Metallic tube fittings for fluid power and general use -
    Part 2: 37 flared fittings
  • ISO 8434-3:1995
    Part 3: O-ring face seal fittings
  • ISO 8434-4:1995
    Part 4: 24 cone connectors with O-ring weld-on nipples
  • ISO 8434-5:1995
    Part 5: Test methods for threaded hydraulic fluid power connections
  • ISO 8491:1998
    Metallic materials - Tube (in full section) - Bend test
  • ISO 8492:1998
    Metallic materials - Tube - Flattening test
  • ISO 8493:1998
    Metallic materials - Tube - Drift-expanding test
  • ISO 8494:1998
    Metallic materials - Tube - Flanging test
  • ISO 8495:1998
    Metallic materials - Tube - Ring-expanding test
  • ISO 8496:1998
    Metallic materials - Tube - Ring tensile test
  • ISO 8497:1994
    Thermal insulation; determination of steady-state thermal transmission properties of thermal insulation for circular pipes
  • ISO 8572:1991
    Pipes and fittings made of glass-reinforced thermosetting plastics (GRP); definitions of terms relating to pressure, including relationships between them, and terms for installation and jointing
  • ISO 8770:2003
    Plastics piping systems for soil and waste discharge (low and high temperature) inside buildings - Polyethylene (PE)
  • ISO 8772:1991
    High density polyethylene (PE-HD) pipes and fittings for buried drainage and sewerage systems; specifications
  • ISO 8773:1991
    Polypropylene (PP) pipes and fittings for buried drainage and sewerage systems; specifications
  • ISO 8796:2004
    Polyethylene PE 32 and PE 40 pipes for irrigation laterals - Susceptibility to environmental stress cracking induced by insert-type fittings - Test method and requirements
  • ISO 9080:2003
    Plastics piping and ducting systems - Determination of the long-term hydrostatic strength of thermoplastics materials in pipe form by extrapolation
  • ISO 9095:1990
    Steel tubes; continuous character marking and colour coding for material identification
  • ISO 9261:2004
    Agricultural irrigation equipment - Emitters and emitting pipe - Specification and test methods
  • ISO 9356:1989
    Polyolefin pipe assemblies with or without jointed fittings; resistance to internal pressure; test method
  • ISO 9623:1997
    PE/metal and PP/metal adaptor fittings for pipes for fluids under pressure - Design lengths and size of threads - Metric series
  • ISO 9625:1993
    Mechanical joint fittings for use with polyethylene pressure pipes for irrigation purposes
  • ISO 9691:1992
    Rubber; recommendations for the workmanship of pipe joint rings; description and classification of imperfections
  • ISO 9803:1993
    Vacuum technology; pipeline fittings; mounting dimensions
  • ISO/TR 9824-1:1990
    Measurement of free surface flow in closed conduits;
    part 1: methods
  • ISO 9808:1990
    Solar water heaters; elastomeric materials for absorbers, connecting pipes and fittings; method of assessment
  • ISO/TR 9824-2:1990
    part 2: equipment
  • ISO 9853:1991
    Injection-moulded unplasticized poly(vinyl chloride) (PVC-U) fittings for pressure pipe systems; crushing test
  • ISO 10147:1994
    Pipes and fittings made of crosslinked polyethylene (PE-X) - Estimation of the degree of crosslinking by determination of the gel content
  • ISO/TR 10358:1993
    Plastics pipes and fittings; combined chemical-resistance classification table
  • ISO 10400:1993
    Petroleum and natural gas industries; formulae and calculation for casing, tubing, drill pipe and line pipe properties
  • ISO 10420:1994
    Petroleum and natural gas industries; flexible pipe systems for subsea and marine riser applications
  • ISO 10422:2001
    Petroleum and natural gas industries - Threading, gauging and thread inspection of casing, tubing and line pipe
  • ISO 10508:1995
    Thermoplastics pipes and fittings for hot and cold water systems
  • ISO 10806:2003
    Pipework - Fittings for corrugated metal hoses
  • ISO/TR 10837:1991
    Determination of the thermal stability of polyethylene (PE) for use in gas pipes and fittings
  • ISO 10928:1997
    Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analysis and their use
  • ISO 10931-1:1997
    Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 1: General
  • ISO 10931-2:1997
    Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 2: Pipes
  • ISO 10931-3:1996
    Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 3: Fittings
  • ISO 10931-4:1997
    Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 4: Valves
  • ISO 10931-5:1998
    Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Part 5: Fitness for purpose of the system
  • ISO/TR 11295:1992
    Techniques for rehabilitation of pipeline systems by the use of plastics pipes and fittings
  • ISO 11413:1996
    Plastics pipes and fittings - Preparation of test piece assemblies between a polyethylene (PE) pipe and an electrofusion fitting
  • ISO 11414:1996
    Plastics pipes and fittings - Preparation of polyethylene (PE) pipe/pipe or pipe/fitting test piece assemblies by butt fusion
  • ISO 11420:1996
    Method for the assessment of the degree of carbon dispersion polyolefin pipe, fittings and compounds
  • ISO 11496:1993
    Seamless and welded steel tubes for pressure purposes; ultrasonic testing of tube ends for the detection of laminar imperfections
  • ISO/TR 11647:1996
    Fusion compatibility of polyethylene (PE) pipes and fittings
  • ISO 11961:1996
    Petroleum and natural gas industries - Steel pipes for use as drill pipe - Specification
  • ISO 12162:1995
    Thermoplastics materials for pipes and fittings for pressure applications - Classification and designation - Overall service (design) coefficient
  • ISO 13664:1997
    Seamless and welded steel tubes for pressure purposes - Magnetic particle inspection of the tube ends for the detection of laminar imperfections
  • ISO 13665:1997
    Seamless and welded steel tubes for pressure purposes - Magnetic particle inspection of the tube body for the detection of surface imperfections
  • ISO 13761:1996
    Plastics pipes and fittings - Pressure reduction factors for polyethylene pipeline systems for use at temperatures above 20
  • ISO 13783:1997
    Plastics piping systems - Unplasticized poly(vinyl chloride) (PVC-U) end-load-bearing double-socket joints - Test method for leaktightness and strength while subjected to bending and internal pressure
