JIS - Pipe, Tube and Fittings Standards
Japanese industrial pipe, tube and fittings standards and specifications from the Japanese Standards Association - JAS.
Industrial pipe, tube and fittings standards and specifications from Japanese Standards Association - JAS:
A. Civil Engineering and Architecture
  • JIS A 5302
    Concrete pipes and reinforced concrete pipes
  • JIS A 5303
    Reinforced spun and centrifugal reinforced concrete pipes
  • JIS A 5314:1998
    Mortar lining for ductile iron pipes
  • JIS A 5322
    Reinforced spun concrete pipes with socket
  • JIS A 5333:1993
    Core type prestressed concrete pipes
  • JIS A 5350:1991
    Fiberglass reinforced plastic mortar pipes
  • JIS A 5405:1982
    Asbestos cement pipes
B. Mechanical Engineering
  • JIS B 0151:2001
    Iron and steel pipe fittings -- Vocabulary
  • JIS B 2301:2004
    Screwed type malleable cast iron pipe fittings
  • JIS B 2302:1998
    Screwed type steel pipe fittings
  • JIS B 2303:1995
    Screwed drainage fittings
  • JIS B 2311:1997
    Steel butt-welding pipe fittings for ordinary use
  • JIS B 2312:1997
  • JIS B 2313:1997
    Steel plate butt-welding pipe fittings
  • JIS B 2316:1997
    Steel socket-welding pipe fittings
  • JIS B 2321:1995
      Aluminumand aluminum alloy butt-welding pipe fittings
  • JIS B 2351:1990
    25 MPa (25 kgf/cm2) bite type tube fittings for hydraulic use
  • JIS B 2354:1991
    Crosslinked polyethylene (XPE) pipe clamp type fittings
  • JIS B 6164:1996
    Compression type tube fittings for machine tools
  • JIS B 8381:1995
    Pneumatic system -- Flexible tubes -- Tube fittings
  • JIS B 8602:2002
    Pipe flanges for refrigerants
  • JIS B 8607:2002
    Flare type and brazing type fittings for refrigerants
C. Electronic and Electrical Engineering
  • JIS C 8380:1993
    Plastic coated steel pipes for cable-ways
D. Automotive Engineering
  • JIS D 3607:1993
    Automotive diesel engines - steel tubes for high-pressure fuel injection pipes
E. Railway Engineering
  • JIS E 4106:1994
    Railway rolling stock - screwed type pipe fittings
  • JIS E 4308:1994
    Railway rolling stock - air filters
F. Shipbuilding
  • JIS F 0014:2000
    Glossary of terms for shipbuilding (hull part -piping)
  • JIS F 0301:1990
    Schemes of thermal insulation of piping for small ships
  • JIS F 0414:1996
    Shipbuilding - internal wiring and piping of engine control console
  • JIS F 0506:1996
    Shipbuilding - applications of copper pipes
  • JIS F 0507:1992
    Small ships - steel pipes - application
  • JIS F 2007:1976
    Mooring pipes
  • JIS F 2030:1978
    Single point mooring pipes
  • JIS F 3016:1996
    Shipbuilding - cast iron pipe sleeve type expansion joints
  • JIS F 3017:1996
    Shipbuilding - cast steel pipe sleeve type expansion joints
  • JIS F 3993:1996
    Discharge pipes for dredger
  • JIS F 3994:1996
    Floaters of discharge pipes for dredger
  • JIS F 3995:1991
    Rubber sleeves for dredge discharge pipes
  • JIS F 7008:1996
    Standard specification of thermal insulation for piping
  • JIS F 7101:1993
    Pipes of ship's machinery - standard velocity of flow
  • JIS F 7102:1989
    Application for gaskets and packing to piping system in machinery space
  • JIS F 7435:1996
    Shipbuilding - brass 30K unions with bite joints
  • JIS F 7436:1996
    Shipbuilding - copper tube 10K brazed unions
  • JIS F 7437:1996
    Shipbuilding - copper tube 10K screwed unions
  • JIS F 7438:1996
    Shipbuilding - steel pipe 10K welding type unions
  • JIS F 7439:1996
    Shipbuilding - steel pipe 10K screwed unions
  • JIS F 7440:1996
    Shipbuilding - copper pipe 20K brazed type unions
  • JIS F 7441:1996
    Shipbuilding - copper pipe 20K screwed unions
  • JIS F 7442:1996
    Shipbuilding - steel pipe 40K welded unions
  • JIS F 7443:1996
    Shipbuilding - steel pipe 40K screwed unions
  • JIS F 7444:1996
    Shipbuilding - steel pipe 100K welded unions
  • JIS F 7445:1996
    Shipbuilding - steel pipe 100K screwed unions
G. Ferrous Materials and Metallurgy
  • JIS G 3429:1988
    Seamless steel tubes for high pressure gas cylinder
  • JIS G 3439
    Seamless steel oil well casing, tubing and drill pipe
  • JIS G 3441:2004
    Alloy steel tubes for machine purposes
  • JIS G 3442:2004
    Galvanized steel pipes for ordinary piping
  • JIS G 3443:2004
    Coated steel pipes for water service
  • JIS G 3444:2004
    Carbon steel tubes for general structural purposes
  • JIS G 3445:1988
    Carbon steel tubes for machine structural purposes
  • JIS G 3446:1994
    Stainless steel pipes for machine and structural purposes
  • JIS G 3447:2004
    Stainless steel sanitary pipes
  • JIS G 3448:2004
    Light gauge stainless steel tubes for ordinary piping
  • JIS G 3451:1987
    Fittings of coated steel pipes for water service
  • JIS G 3452:2004
    Carbon steel pipes for ordinary piping
  • JIS G 3454:1988
    Carbon steel pipes for pressure service
  • JIS G 3455:1988
    Carbon steel pipes for high pressure service
  • JIS G 3456:2004
    Carbon steel pipes for high temperature service
  • JIS G 3457:1988
    Arc welded carbon steel pipes
  • JIS G 3458:1988
    Alloy steel pipes
  • JIS G 3459:2004
  • JIS G 3460:1988
    Steel pipes for low temperature service
  • JIS G 3465:1988
    Seamless steel tubes for drilling
  • JIS G 3466:1988
    Carbon steel square pipes for general structural purposes
  • JIS G 3468, Publication date:2004-03-20
    Large diameter welded stainless steel pipes
  • JIS G 3469:2002
    Polyethylene coated steel pipes
  • JIS G 3471:1977
    Corrugated steel pipes and sections
  • JIS G 3474:1995
    High tensile strength steel tubes for tower structural purposes
  • JIS G 3491:2004
    Asphalt protective coatings for steel water pipe
  • JIS G 3492:1993
    Coal-tar enamel protective coatings for steel water pipe
  • JIS G 4903:1991
    Seamless nickel-chromium-iron alloy pipes
  • JIS G 5201:1991
    Centrifugally cast steel pipes for welded structure
  • JIS G 5202:1991
    Centrifugally cast steel pipes for high temperature and high pressure service
  • JIS G 5525:2000
    Cast-iron drainage pipes and fittings
  • JIS G 5526:1998
    Ductile iron pipes
  • JIS G 5527:1998
    Ductile iron fittings
  • JIS G 5528:1984
    Epoxy-powder coating for interior of ductile iron pipes and fittings
H. Non-ferrous Metals and Metallurgy
  • JIS H 0502:1986
    Method of eddy current testing for copper and copper alloy pipes and tubes
  • JIS H 0515:1992
    Eddy current inspection of titanium pipes and tubes
  • JIS H 0516:1992
    Ultrasonic inspection of titanium pipes and tubes
  • JIS H 3300:1997
    Copper and copper alloy seamless pipes and tubes
  • JIS H 3320:1992
    Copper and copper alloy welded pipes and tubes
  • JIS H 3401:2001
    Pipe fittings of copper and copper alloys
  • JIS H 4080:1999
    Aluminum and aluminum alloys extruded tubes and cold-drawn tubes
  • JIS H 4090:1990
    Aluminum and aluminum alloy welded pipes and tubes
  • JIS H 4202:1998
    Magnesium alloy seamless pipes and tubes
  • JIS H 4311:1993
    Lead and lead alloy tubes for common industries
  • JIS H 4312:2000
    Polyethylene lining lead pipes for water supply
  • JIS H 4552:2000
    Nickel and nickel alloy seamless pipes and tubes
  • JIS H 4630:2001
    Titanium and titanium alloy seamless pipes
  • JIS H 4635:2001
    Titanium and titanium alloy welded pipes
K. Chemical Engineering
  • JIS K 6739:2004
    Unplasticized poly(vinyl chloride) (PVC-U) pipe fittings for drain
  • JIS K 6741:2004
    Unplasticized poly(vinyl chloride) (PVC-U) pipes
  • JIS K 6742:2004
    Unplasticized poly(vinyl chloride) (PVC-U) pipes for water supply
  • JIS K 6761:2004
    Polyethylene pipes for General Purposes
  • JIS K 6762:2004
    Double wall polyethylene pipes for water supply
  • JIS K 6743:2004
    Unplasticized poly (vinyl chloride) (PVC-U) pipe fittings for water supply
  • JIS K 6769:2004
    Crosslinked polyethylene (PE-X) pipes
  • JIS K 6770:2004
    Crosslinked polyethylene (PE-X) pipe fittings
  • JIS K 6774:1998
    Polyethylene pipes for the supply of gaseous fuels
  • JIS K 6775-1:1998
    Polyethylene pipe-fittings for the supply of gaseous fuels --
    Part 1: Heatfusion fittings
  • JIS K 6775-2:1998
    Part 2: Spigot fittings
  • JIS K 6775-3:1998
    Part 3: Electrofusion fittings
  • JIS K 6776:2004
    Chlorinated poly(vinyl chloride) (PVC-C) pipes for hot and cold water supply
  • JIS K 6777:2004
    Chlorinated poly(vinyl chloride) (PVC-C) pipe fittings for hot and cold water supply
  • JIS K 6778:2004
    Polybutene (PB) pipes
  • JIS K 6779:2004
    Polybutene (PB) pipe fittings
  • JIS K 6897:1995
    Polyetrafluoroethylene pipes
P. Pulp and Paper
  • JIS R 1201:1991
    Clay pipes
  • JIS R 1511:1991
    Conical flanged straight pipes of acid proof porcelains for chemical industry
  • JIS R 1512:1991
    Conical flanged 90 degrees bent pipes of acid proof porcelains for chemical industry
  • JIS R 1513:1991
    Conical flanged 45 degrees bent pipes of acid proof porcelains for chemical industry
  • JIS R 1514:1991
    Conical flanged tee pipes pipes of acid proof porcelains for chemical industry
  • JIS R 1534:1991
    Metal joint for conical flanged pipes of acid proof porcelains for chemical industry
S. Domestic Wares
  • JIS S 2080:1994
    Exhaust pipes for burning appliances
  • JIS S 3028:1994
    Oil discharge copper pipe for oil burning appliances
T. Medical Equipment and Safety Appliances
  • JIS T 7101:1993
    Medical gas pipeline systems
  • JIS T 9211:1990
    Pipes for endoskeletal type of lower limb prostheses
Z. Miscellaneous, Packaging, Welding, Radioactivity, etc.
  • JIS Z 1604:1995
    Plugs and flanges for steel drums
