Carbon Steel Pipes - Comparing American & European Standards
Comparing standards of carbon steel pipes from USA, Germany, UK and Sweden.
The table below can be used to compare carbon steel piping standards from America - USA, and Europe - Germany, British (UK) and Sweden
USAUKGermanySweden
ASTM A 53 BS3601 DIN 1629
Grade A SMLS HFS 22 & CDS 22 St 35 SIS 1233-05
Grade B SMLS HFS 27 & CDS 27 St 45 SIS 1434-05
ASTM A 53 BS3601 DIN 1626
Grade A ERW ERW 22 Blatt 3 St 34-2 ERW
Grade B ERW ERW 27 Blatt 3 St 37-2 ERW
FBW BW 22 Blatt 3 St 34-2 FBW
ASTM A 106 BS3602 DIN 17175 2)
Grade A HFS 23 St 35-8 SIS 1233-06
Grade B HFS 27 St 45-8 SIS 1435-05
Grade C HFS 35
ASTM A 134 BS3601 DIN 1626
  EFW Blatt 2 EFW
ASTM A 135 BS3601 DIN 1626
Grade A ERW 22 Blatt 3 St 34-2 ERW SIS 1233-06
Grade B ERW 27 Blatt 3 St 37-2 ERW SIS 1434-06
ASTM A 139 BS3601 DIN 1626
Grade A EFW 22 Blatt 2 St 37
Grade B EFW 27 Blatt 2 St 42
ASTM A 155 Class 2 BS3602 DIN 1626, Blatt 3 with certification C
C45   St 34-2
C50   St 37-2
C55   St 42-2
KC55 EFW 28 St 42-2 2)
KC60   St 42-2 2)
KC65 EFW 28S St 52-2
KC70   St 52-2
API 5L BS3601 DIN 1629
Grade B SMLS HFS 27 & CDS 27 St 45 SIS 1434-06 *
API 5L BS3601 DIN 1625
Grade B ERW ERW 27 1) Blatt 4 St 37-2 ERW
API 5L BS3601 Double welded DIN 1626
Grade A EFW ERW 22 Blatt 3 St 34-2 FW
Grade B EFW ERW 27 1) Blatt 4 St 37-2 FW
API 5L BS3601 DIN 1626
1) Specify API 5L Grade B testing procedures for these steels
2) Specify SI-killed
  • Piping Codes and Standards
  • Piping Systems
  • The Engineering ToolBox (2003). Carbon Steel Pipes - Comparing American & European Standards. [online] Available at: https://www.engineeringtoolbox.com/carbon-steel-pipes-standards-d_31.html [Accessed Day Month Year].
