Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Online Pipe Formula Calculator
The calculator is based on the piping formulas and equations below.
Pipes
Moment of Inertia
Moment of inertia can be expressed as
I  = π (do4 - di4) / 64
   ≈ 0.0491 (do4 - di4)                            (1)
I = moment of inertia (in4)
do = outside diameter (in)
di = inside diameter (in)
Section Modulus
Section modulus can be expressed as
S  = 0.0982 (do4 - di4) / do                            (2)
S = section modulus (in3)
Section modulus is a geometric property for a given cross-section used in the design of beams or flexural members.
Transverse Metal Area
Transverse metal area can be expressed as
Am  = π (do2 - di2) / 4                              (3)
Am = transverse metal area (in2)
External Pipe Surface
External pipe or tube surface per ft of length can be expressed as
Ao  = π do / 12                              (4)
Ao = external  pipe surface area (ft2 per ft pipe)
Internal Pipe Surface
Internal pipe or tube surface per ft of length can be expressed as
Ai  = π di / 12                            (5)
Ai = internal  pipe surface area (ft2 per ft pipe)
Transverse Internal Area
Transverse internal area can be expressed as
Aa  = 0.7854 di2                       (6)
Aa = transverse internal area (in2)
Circumference External
External circumference can be expressed as
Ce  = π do                      (7)
Ce =  external circumference (in)
Circumference Internal
Internal circumference can be expressed as
Ci  = π di                       (8)
Ci =  internal circumference (in)
Estimating Pipe Circumference and Section Area
Pipes - Circumferences and Section Areas
Nominal Pipe Size
(in)
Circumference
(in)
Section Area
(sq.in.)
1/4 0.785 0.049
3/8 1.178 0.110
1/2 1.571 0.196
3/4 2.356 0.442
1 3.142 0.785
1 1/4 3.927 1.227
1 1/2 4.712 1.767
2 6.283 3.142
2 1/2 7.854 4.909
3 9.425 7.069
3 1/2 11.00 9.621
4 12.57 12.57
5 15.71 19.64
6 18.85 28.27
8 25.13 50.27
10 31.42 78.54
12 37.70 113.1
15 47.12 176.7
  • The Engineering ToolBox (2008). Pipe and Tubing Formulas. [online] Available at: https://www.engineeringtoolbox.com/pipe-formulas-d_1335.html [Accessed Day Month Year].
