Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
The Elastic Section Modulus of a beam is the ratio of the cross section Area Moment of Inertia to its greatest distance from the neutral axis.
Area moment of inertia - Square section
For a simple solid Square the Section Modulus can be expressed as
Sx = Sy = a3 / 6                                         (1)
S = Elastic Section Modulus - related to bending around x vs. y axis (m3, cm3, ft3, in3)
a = square side distance (m, in, ft..)
Converter
Convert from Multiply with
Convert to
m3 cm3 ft3 in3
m3 1 106 35.31466 61,023.76
cm3 10-6 1 3.5 10-5 6.1 10-2
ft3 0.02831685 28373 1 1728
in3 0.00001638706 16.38 5.78 10-4 1
Example - Convert Section Modulus in unit in3 to cm3
12 in3 can be converted to cm3 by multiplying with 16.38 - as
(12 in3) (16.38 cm3/in3) = 196.6 cm3
  • Beams and Columns
  • Mechanics
  • The Engineering ToolBox (2008). Section Modulus - Unit Converter. [online] Available at: https://www.engineeringtoolbox.com/section-modulus-conversion-d_1332.html [Accessed Day Month Year].
