Modulus of Rigidity
Modulus of Rigidity - G - (Shear Modulus) is the coefficient of elasticity for a shearing force. It is defined as
- "the ratio of shear stress to the displacement per unit sample length (shear strain)"
Modulus of Rigidity can be experimentally determined from the slope of a stress-strain curve created during tensile tests conducted on a sample of the material.
The definition of Modulus of Rigidity:
- the ratio of shear stress to the displacement per unit sample length (shear strain)
Modulus of Rigidity of some Common Materials
Material | Shear Modulus - G - (GPa) (106 psi) |
Aluminum Alloys | 27 |
Aluminum, 6061-T6 | 24 |
Aluminum, 2024-T4 | 28 |
Beryllium Copper | 48 |
Brass | 40 |
Bronze | 44.8 |
Cadmium | 19 |
Carbon Steel | 77 |
Cast Iron | 41 |
Chromium | 115 |
Concrete | 21 |
Copper | 45 |
Glass | 26.2 |
Glass, 96% silica | 19 |
Inconel | 79 |
Iron, Ductile | 63 - 66 |
Iron, Malleable | 64 |
Kevlar | 19 |
Lead | 13.1 |
Magnesium | 16.5 |
Molybdenum | 118 |
Monel metal | 66 |
Nickel Silver | 48 |
Nickel Steel | 76 |
Nylon | 4.1 |
Phosphor Bronze | 41 |
Plywood | 0.62 |
Polycarbonate | 2.3 |
Polyethylene | 0.12 |
Rubber | 0.0003 |
Structural Steel | 79.3 |
Stainless Steel | 77.2 |
Steel, Cast | 78 |
Steel, Cold-rolled | 75 |
Tin | 18 |
Titanium, Grade 2 | 41 |
Titanium, Grade 5 | 41 |
Titanium, 10% Vanadium | 42 |
Tungsten | 161 |
Wood, Douglas Fir | 13 |
Zinc | 43 |
Z-nickel | 76 |
- 1 GPa = 109 Pa = 0.145 x 106 psi (lbf/in2)
- 1 x 106 psi = 6.9 GPa
Mechanics
The relationships between forces, acceleration, displacement, vectors, motion, momentum, energy of objects and more. -
Statics
Tensile stress and Hooke's Law. -
Bulk Modulus and Fluid Elasticities
Introduction to - and definition of - Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids. -
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites. -
Metals - Strength vs. Temperature
The influence of temperature on the strength of metals. -
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys. -
Elastic properties and Young's modulus for metals and alloys like cast iron, carbon steel and more. -
Poisson's Ratio
When a material is stretched in one direction it tends to get thinner in the other two directions. -
Poisson's Ratios Metals
Some metals and their Poisson's Ratios. -
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness. -
Rotating Shafts - Torque
Torsional moments acting on rotating shafts. -
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units. -
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area. -
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood -
Square Hollow Structural Sections - HSS
Weight, cross sectional area, moments of inertia - Imperial units -
Steel Angles - Unequal Legs
Dimensions and static parameters of steel angles with unequal legs - metric units. -
Endurance limits and fatigue stress for steels. -
Stiffness
Stiffness is resistance to deflection. -
Stress is force per unit area - strain is the deformation of a solid due to stress. -
Physical properties of thermoplastics like ABS, PVC, CPVC, PE, PEX, PB and PVDF. -
Trusses
Common types of trusses. -
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
