Poisson's Ratio – Definition, Values for Materials, and Applications
Poisson's ratio, a key material property describing the relationship between axial and lateral strain in solid materials. Typical Poisson's ratio values for metals, polymers, ceramics, and more, along with practical applications in engineering and mechanics.
When a sample of material is stretched in one direction it tends to get thinner in the lateral direction - and if a sample is compressed in one direction it tends to get thicker in the lateral direction.
Poisson's ratio
Poisson's ratio is
  • the ratio of the relative contraction strain (transverse, lateral or radial strain) normal to the applied load - to the relative extension strain (or axial strain) in the direction of the applied load
Poisson's Ratio can be expressed as
μ = - εt / εl                                (1)
μ = Poisson's ratio
εt = transverse strain (m/m, ft/ft)
εl = longitudinal or axial strain (m/m, ft/ft)
Strain is defined as "deformation of a solid due to stress".
Longitudinal (or axial) strain can be expressed as
εl = dl / L                              (2)
εl = longitudinal or axial strain (dimensionless - or m/m, ft/ft)
dl = change in length (m, ft)
L = initial length (m, ft)
Contraction (or transverse, lateral or radial) strain can be expressed as
εt = dr / r                              (3)
εt = transverse, lateral or radial strain (dimensionless - or m/m, ft/ft)
dr = change in radius (m, ft)
r = initial radius (m, ft)
Eq. 1, 2 and 3 can be combined to
μ = - ( dr / r) / ( dl / L)                     (4)
Example - Stretching Aluminum
An aluminum bar with length 10 m and radius 100 mm (100×10-3 m) is stretched 5 mm (5×10-3 m) . The radial contraction in lateral direction can be rearranged to
dr = - μ ⋅ r ⋅ dl / L                 (5)
With Poisson's ratio for aluminum 0.334 - the contraction can be calculated as
dr = - 0.334 ⋅ ( 100 ⋅ 10-3 m) ( 5 ⋅ 10-3 m) / (10 m)
= 1.7 10-5 m
= 0.017 mm
Poisson's Ratios for Common Materials
For most common materials the Poisson's ratio is in the range 0 - 0.5. Typical Poisson's Ratios for some common materials are indicated below.
Poisson's Ratios common Materials
MaterialPoisson's Ratio
- μ -
Upper limit 0.5
Aluminum 0.334
Aluminum, 6061-T6 0.35
Aluminum, 2024-T4 0.32
Beryllium Copper 0.285
Brass, 70-30 0.331
Brass, cast 0.357
Bronze 0.34
Clay 0.41
Concrete 0.1 - 0.2
Copper 0.355
Cork 0
Glass, Soda 0.22
Glass, Float 0.2 - 0.27
Granite 0.2 - 0.3
Ice 0.33
Inconel 0.27 - 0.38
Iron, Cast - gray 0.211
Iron, Cast 0.22 - 0.30
Iron, Ductile 0.26 - 0.31
Iron, Malleable 0.271
Lead 0.431
Limestone 0.2 - 0.3
Magnesium 0.35
Magnesium Alloy 0.281
Marble 0.2 - 0.3
Molybdenum 0.307
Monel metal 0.315
Nickel Silver 0.322
Nickel Steel 0.291
Polystyrene 0.34
Phosphor Bronze 0.359
Rubber 0.48 - ~0.5
Sand 0.29
Sandy loam 0.31
Sandy clay 0.37
Stainless Steel 18-8 0.305
Steel, cast 0.265
Steel, Cold-rolled 0.287
Steel, high carbon 0.295
Steel, mild 0.303
Titanium (99.0 Ti) 0.32
Wrought iron 0.278
Z-nickel 0.36
Zinc 0.331
