EN 13348 Seamless, Round Copper Tubes for Medical Gases or Vacuum - Dimensions
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Dimensions of copper tubes according EN 13348 Copper and copper alloys. Seamless, round copper tubes for medical gases or vacuum:
Nominal Outside Diameter
- d -
(mm)
Nominal Wall Thickness - e - (mm)
0.50.60.70.80.91.01.11.21.52.02.53.0
12
15
22
28
35
42
54
66.7
76.1
108
133
159
219
Recommended
  • 1 inch = 25.4 mm
Example - Designation of EN 13348 Copper Tube
  • Copper tube EN 13348 R290 15×1.0
where R290 is material temper.
Material Temper
Copper tube EN 13348 - Hardness and Strength
Material TemperTensile StrengthElongation min.Vickers Hardness
DesignationCommonly used term(MPa)(%)HV5
R250 half hard 250 30, 20 75 - 100
R290 hard 290 3 over 100
EN 1173 - Letter symbols for Property Designations
  • A Elongation
  • B Spring bending limit
  • G Grain size
  • H Hardness (Brinell for castings, Vickers for wrought products)
  • M (as) Manufactured, i.e. without specified mechanical properties
  • R Tensile strength (like R250 - 250 MPa)
  • Y 0.2% proof strength
Typical Available Dimensions
Plain Straight Tubes
Copper tube EN 13348 - Typical Available Dimensions
(mm)
Tube Length
(m)
Wall Thickness
(mm)
12 6 0.6
15 3, 6 0.7
22 3, 6 0.9
28 3, 6 0.9
35 6 1.0
42 6 1.0
54 6 1.0
67 6 1.5
76 6 1.5
108 6 1.5
133 6 1.5
159 6 2.0
219 6 3.0
  • The Engineering ToolBox (2018). EN 13348 Seamless, Round Copper Tubes for Medical Gases or Vacuum - Dimensions. [online] Available at: https://www.engineeringtoolbox.com/EN-13348-seamless-round-copper-tubes-for-medical-gases-or-vacuum-d_2126.html [Accessed Day Month Year].
