ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
Dimensions of PVC pipes according ASTM D2241 Standard Specification for Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series).
Nominal Pipe Size
(in)
Average Outside Diameter
(in)
Minimum Wall Thickness (in)
SDR 64SDR 41SDR 32.5SDR 26SDR 21SDR 17SDR 13.5
1/8 0.405 0.060
1/4 0.540 0.060
3/8 0.675 0.060
1/2 0.840 0.062
3/4 1.050 0.060 0.062 0.078
1 1.315 0.060 0.063 0.077 0.097
1 1/4 1.660 0.060 0.064 0.079 0.098 0.123
1 1/2 1.900 0.060 0.073 0.090 0.112 0.141
2 2.375 0.073 0.091 0.113 0.140 0.176
2 1/2 2.875 0.088 0.110 0.137 0.169 0.213
3 3.500 0.085 0.108 0.135 0.167 0.206 0.259
3 1/2 4.000 0.098 0.123 0.154 0.190 0.235 0.296
4 4.500 0.070 0.110 0.138 0.173 0.214 0.265 0.333
5 5.563 0.087 0.136 0.171 0.214 0.265 0.327 0.412
6 6.625 0.104 0.162 0.204 0.255 0.316 0.390 0.491
8 8.625 0.135 0.210 0.265 0.332 0.410 0.508
10 10.750 0.168 0.262 0.331 0.413 0.511 0.632
12 12.750 0.199 0.311 0.392 0.490 0.606 0.750
14 14.000 0.341 0.430 0.538 0.666 0.823
16 16.000 0.390 0.492 0.615 0.762 0.941
18 18.000 0.439 0.554 0.692 0.857 1.059
20 20.000 0.488 0.615 0.769 0.952 1.176
24 24.000 0.585 0.738 0.923 1.143 1.412
30 30.000 0.732 0.923 1.154 1.428 1.765
36 36.000 0.878 1.108 1.385 1.714 2.118
For sizes 1 1/4" and larger ASTM D2665 for DWV pipe is comparable to ASTM D1785 Schedule 40.
PVC pipes - SDR series vs. wall thickness and dimension
  • The Engineering ToolBox (2018). ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions. [online] Available at: https://www.engineeringtoolbox.com/ASTM-D2241-pvc-sdr-pipe-d_2129.html [Accessed Day Month Year].
