PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Friction loss and flow velocities in PVC and CPVC pipes Schedule 80 with water are indicated in the table below. The table may can be used for pipes in other thermoplastic materials where the inner diameter corresponds to PVC Pipe
Schedule 80
- 1 ft (foot) = 0.3048 m
- 1 ft/s = 0.3048 m/s
- 1 gal (US)/min =6.30888x10-5 m3/s = 0.0227 m3/h = 0.0631 dm3(liter)/s = 2.228x10-3 ft3/s = 0.1337 ft3/min
- 1 psi/100 ft = 2.3 ftH2O/100 ft = 2288 mmH2O/100 ft = 22.46 kPa/100 m
Note! Velocities should in general not exceed 5 feet per second to avoid noise and damaging wear and tear of pipes and fittings.
The values can be used to calculate minor pressure loss with the Equivalent Pipe Length Method.
Volume Flow (gal/min) |
Volume Flow (gal/hr) |
Velocity (ft/sec) |
Friction Head (ftH2O/100 ft) |
Friction Loss (psi/100 ft) |
1 | 60 | 1.5 | 4.0 | 1.7 |
2 | 120 | 3.0 | 8.0 | 3.5 |
5 | 300 | 7.4 | 45.2 | 19.6 |
7 | 420 | 10.3 | 83.1 | 36.0 |
Velocity (ft/sec) |
Friction Head (ft/100ft) |
1 | 60 | 0.7 | 0.9 | 0.4 |
2 | 120 | 1.6 | 1.7 | 0.7 |
5 | 300 | 3.9 | 9.7 | 4.2 |
7 | 420 | 5.5 | 11.8 | 7.7 |
10 | 600 | 7.8 | 33.8 | 14.7 |
15 | 900 | 11.8 | 71.7 | 31.1 |
Velocity (ft/sec) |
2 | 120 | 0.9 | 0.9 | 0.4 |
5 | 300 | 2.3 | 2.6 | 1.2 |
7 | 420 | 3.3 | 5.0 | 2.2 |
10 | 600 | 4.7 | 9.6 | 4.2 |
15 | 900 | 7.0 | 20.4 | 8.8 |
20 | 1200 | 9.4 | 34.7 | 15.0 |
25 | 1500 | 11.7 | 52.4 | 22.7 |
30 | 1800 | 14.0 | 73.5 | 31.8 |
Velocity (ft/sec) |
2 | 120 | 0.5 | 0.2 | 0.1 |
5 | 300 | 1.3 | 0.7 | 0.3 |
7 | 420 | 1.8 | 1.2 | 0.5 |
10 | 600 | 2.6 | 2.3 | 1.0 |
15 | 900 | 3.9 | 4.9 | 2.1 |
20 | 1200 | 5.2 | 8.3 | 3.6 |
25 | 1500 | 6.5 | 12.6 | 5.4 |
30 | 1800 | 7.8 | 17.6 | 7.6 |
35 | 2100 | 9.1 | 23.4 | 10.1 |
40 | 2400 | 10.4 | 30.0 | 13.0 |
45 | 2700 | 11.7 | 37.3 | 16.1 |
50 | 3000 | 13.0 | 45.3 | 19.6 |
Velocity (ft/sec) |
2 | 120 | 0.4 | 0.1 | 0.04 |
5 | 300 | 0.9 | 0.3 | 0.1 |
7 | 420 | 1.3 | 0.6 | 0.2 |
10 | 600 | 1.9 | 1.0 | 0.5 |
15 | 900 | 2.8 | 2.2 | 1.0 |
20 | 1200 | 3.8 | 3.8 | 1.6 |
25 | 1500 | 4.7 | 5.7 | 2.5 |
30 | 1800 | 5.6 | 8.0 | 3.4 |
35 | 2100 | 6.6 | 10.6 | 4.6 |
40 | 2400 | 7.5 | 13.6 | 5.9 |
45 | 2700 | 8.4 | 16.9 | 7.3 |
50 | 3000 | 9.4 | 20.5 | 8.9 |
60 | 3600 | 11.3 | 28.7 | 12.4 |
Velocity (ft/sec) |
5 | 300 | 0.6 | 0.1 | 0.04 |
7 | 420 | 0.8 | 0.2 | 0.07 |
10 | 600 | 1.1 | 0.3 | 0.1 |
15 | 900 | 1.7 | 0.6 | 0.3 |
20 | 1200 | 2.2 | 1.1 | 0.5 |
25 | 1500 | 2.8 | 1.6 | 0.7 |
30 | 1800 | 3.4 | 2.3 | 1.0 |
35 | 2100 | 3.9 | 3.0 | 1.3 |
40 | 2400 | 4.5 | 3.8 | 1.7 |
45 | 2700 | 5.0 | 4.8 | 2.1 |
50 | 3000 | 5.6 | 5.8 | 2.5 |
60 | 3600 | 6.7 | 8.1 | 3.5 |
70 | 4200 | 7.8 | 10.8 | 4.7 |
75 | 4500 | 8.4 | 12.3 | 5.3 |
80 | 4800 | 8.9 | 13.8 | 6.0 |
90 | 5400 | 10.1 | 17.2 | 7.5 |
100 | 6000 | 11.2 | 20.9 | 9.1 |
Velocity (ft/sec) |
5 | 300 | 0.4 | 0.05 | 0.02 |
7 | 420 | 0.5 | 0.07 | 0.03 |
10 | 600 | 0.8 | 0.1 | 0.05 |
15 | 900 | 1.2 | 0.3 | 0.1 |
20 | 1200 | 1.6 | 0.4 | 0.2 |
25 | 1500 | 2.0 | 0.7 | 0.3 |
30 | 1800 | 2.3 | 0.9 | 0.4 |
35 | 2100 | 2.7 | 1.3 | 0.5 |
40 | 2400 | 3.1 | 1.6 | 0.7 |
45 | 2700 | 3.5 | 2.0 | 0.9 |
50 | 3000 | 3.9 | 2.4 | 1.1 |
60 | 3600 | 4.7 | 3.4 | 1.5 |
70 | 4200 | 5.5 | 4.5 | 2.0 |
75 | 4500 | 5.9 | 5.1 | 2.2 |
80 | 4800 | 6.2 | 5.8 | 2.5 |
90 | 5400 | 7.0 | 7.2 | 3.1 |
100 | 6000 | 7.8 | 8.7 | 3.8 |
125 | 7500 | 9.8 | 13.2 | 5.7 |
150 | 9000 | 11.7 | 18.5 | 8.0 |
Velocity (ft/sec) |
5 | 300 | 0.3 | 0.02 | 0.01 |
7 | 420 | 0.4 | 0.03 | 0.01 |
10 | 600 | 0.5 | 0.04 | 0.02 |
15 | 900 | 0.8 | 0.09 | 0.04 |
20 | 1200 | 1.0 | 0.2 | 0.07 |
25 | 1500 | 1.3 | 0.2 | 0.1 |
30 | 1800 | 1.5 | 0.3 | 0.1 |
35 | 2100 | 1.7 | 0.4 | 0.2 |
40 | 2400 | 2.0 | 0.5 | 0.2 |
45 | 2700 | 2.2 | 0.7 | 0.3 |
50 | 3000 | 2.5 | 0.8 | 0.4 |
60 | 3600 | 3.0 | 1.1 | 0.5 |
70 | 4200 | 3.5 | 1.5 | 0.7 |
75 | 4500 | 3.7 | 1.7 | 0.7 |
80 | 4800 | 4.0 | 1.9 | 0.8 |
90 | 5400 | 4.5 | 2.4 | 1.0 |
100 | 6000 | 5.0 | 2.9 | 1.3 |
125 | 7500 | 6.2 | 4.4 | 1.9 |
150 | 9000 | 7.5 | 6.2 | 2.7 |
175 | 10500 | 8.7 | 8.3 | 3.6 |
200 | 12000 | 10.0 | 10.6 | 4.6 |
250 | 15000 | 12.5 | 16.0 | 6.9 |
Velocity (ft/sec) |
20 | 1200 | 0.6 | 0.04 | 0.02 |
25 | 1500 | 0.7 | 0.06 | 0.03 |
30 | 1800 | 0.9 | 0.08 | 0.04 |
35 | 2100 | 1.0 | 0.1 | 0.05 |
40 | 2400 | 1.2 | 0.1 | 0.06 |
45 | 2700 | 1.3 | 0.2 | 0.07 |
50 | 3000 | 1.4 | 0.2 | 0.09 |
60 | 3600 | 1.7 | 0.3 | 0.1 |
70 | 4200 | 2.0 | 0.4 | 0.2 |
75 | 4500 | 2.2 | 0.5 | 0.2 |
80 | 4800 | 2.3 | 0.5 | 0.2 |
90 | 5400 | 2.6 | 0.6 | 0.3 |
100 | 6000 | 2.9 | 0.8 | 0.3 |
125 | 7500 | 3.6 | 1.2 | 0.5 |
150 | 9000 | 4.3 | 1.6 | 0.7 |
175 | 10500 | 5.0 | 2.2 | 0.9 |
200 | 12000 | 5.7 | 2.8 | 1.2 |
250 | 15000 | 7.2 | 4.2 | 1.8 |
300 | 18000 | 8.6 | 5.8 | 2.5 |
350 | 21000 | 10.0 | 7.8 | 3.4 |
400 | 24000 | 11.5 | 9.9 | 4.3 |
Velocity (ft/sec) |
30 | 1800 | 0.5 | 0.03 | 0.01 |
35 | 2100 | 0.6 | 0.04 | 0.02 |
40 | 2400 | 0.7 | 0.04 | 0.02 |
45 | 2700 | 0.8 | 0.06 | 0.03 |
50 | 3000 | 0.9 | 0.07 | 0.03 |
60 | 3600 | 1.1 | 0.1 | 0.04 |
70 | 4200 | 1.3 | 0.1 | 0.06 |
75 | 4500 | 1.3 | 0.1 | 0.06 |
80 | 4800 | 1.4 | 0.2 | 0.07 |
90 | 5400 | 1.6 | 0.2 | 0.09 |
100 | 6000 | 1.8 | 0.2 | 0.1 |
125 | 7500 | 2.3 | 0.4 | 0.2 |
150 | 9000 | 2.7 | 0.5 | 0.2 |
175 | 10500 | 3.2 | 0.7 | 0.3 |
200 | 12000 | 3.6 | 0.9 | 0.4 |
250 | 15000 | 4.5 | 1.3 | 0.6 |
300 | 18000 | 5.4 | 1.9 | 0.8 |
350 | 21000 | 6.3 | 2.5 | 1.1 |
400 | 24000 | 7.2 | 3.2 | 1.4 |
450 | 27000 | 8.1 | 4.0 | 1.7 |
500 | 30000 | 9.0 | 4.8 | 2.1 |
Velocity (ft/sec) |
50 | 3000 | 0.6 | 0.03 | 0.01 |
60 | 3600 | 0.8 | 0.04 | 0.02 |
70 | 4200 | 0.9 | 0.05 | 0.02 |
75 | 4500 | 0.9 | 0.06 | 0.03 |
80 | 4800 | 1.0 | 0.07 | 0.03 |
90 | 5400 | 1.1 | 0.08 | 0.04 |
100 | 6000 | 1.3 | 0.1 | 0.04 |
125 | 7500 | 1.6 | 0.2 | 0.07 |
150 | 9000 | 1.9 | 0.2 | 0.1 |
175 | 10500 | 2.2 | 0.3 | 0.1 |
200 | 12000 | 2.5 | 0.4 | 0.2 |
250 | 15000 | 3.1 | 0.6 | 0.2 |
300 | 18000 | 3.8 | 0.8 | 0.3 |
350 | 21000 | 4.4 | 1.0 | 0.5 |
400 | 24000 | 5.0 | 1.3 | 0.6 |
450 | 27000 | 5.6 | 1.7 | 0.7 |
500 | 30000 | 6.3 | 2.0 | 0.9 |
750 | 45000 | 9.4 | 4.3 | 1.8 |
1000 | 60000 | 12.5 | 7.2 | 3.1 |
Velocity (ft/sec) |
125 | 7500 | 0.9 | 0.05 | 0.02 |
150 | 9000 | 1.1 | 0.05 | 0.02 |
175 | 10500 | 1.3 | 0.08 | 0.03 |
200 | 12000 | 1.4 | 0.09 | 0.04 |
250 | 15000 | 1.8 | 0.1 | 0.06 |
300 | 18000 | 2.1 | 0.2 | 0.09 |
350 | 21000 | 2.5 | 0.3 | 0.1 |
400 | 24000 | 2.9 | 0.3 | 0.2 |
450 | 27000 | 3.2 | 0.4 | 0.2 |
500 | 30000 | 3.6 | 0.5 | 0.2 |
750 | 45000 | 5.4 | 1.1 | 0.5 |
1000 | 60000 | 7.1 | 1.8 | 0.8 |
1250 | 75000 | 8.9 | 2.8 | 1.2 |
1500 | 90000 | 10.7 | 4.0 | 1.7 |
Velocity (ft/sec) |
200 | 12000 | 0.9 | 0.04 | 0.02 |
250 | 15000 | 1.1 | 0.05 | 0.02 |
300 | 18000 | 1.4 | 0.07 | 0.03 |
350 | 21000 | 1.6 | 0.09 | 0.04 |
400 | 24000 | 1.8 | 0.1 | 0.05 |
450 | 27000 | 2.0 | 0.1 | 0.06 |
500 | 30000 | 2.3 | 0.2 | 0.07 |
750 | 45000 | 3.4 | 0.4 | 0.2 |
1000 | 60000 | 4.5 | 0.6 | 0.3 |
1250 | 75000 | 5.7 | 0.9 | 0.4 |
1500 | 90000 | 6.8 | 1.3 | 0.6 |
2000 | 120000 | 9.1 | 2.2 | 1.0 |
2500 | 150000 | 11.3 | 3.3 | 1.4 |
Velocity (ft/sec) |
350 | 21000 | 1.1 | 0.04 | 0.02 |
400 | 24000 | 1.3 | 0.05 | 0.02 |
450 | 27000 | 1.4 | 0.06 | 0.03 |
500 | 30000 | 1.6 | 0.07 | 0.03 |
750 | 45000 | 2.4 | 0.2 | 0.07 |
1000 | 60000 | 3.2 | 0.3 | 0.1 |
1250 | 75000 | 4.0 | 0.4 | 0.2 |
1500 | 90000 | 4.8 | 0.6 | 0.2 |
2000 | 120000 | 6.4 | 0.9 | 0.4 |
2500 | 150000 | 8.0 | 1.4 | 0.6 |
3000 | 180000 | 9.6 | 2.0 | 0.9 |
3500 | 210000 | 11.2 | 2.7 | 1.2 |
4000 | 240000 | 12.8 | 3.4 | 1.5 |
Velocity (ft/sec) |
500 | 30000 | 1.3 | 0.04 | 0.02 |
750 | 45000 | 2.0 | 0.09 | 0.04 |
1000 | 60000 | 2.6 | 0.2 | 0.07 |
1250 | 75000 | 3.3 | 0.3 | 0.1 |
1500 | 90000 | 3.9 | 0.3 | 0.2 |
2000 | 120000 | 5.2 | 0.6 | 0.3 |
2500 | 150000 | 6.5 | 0.9 | 0.4 |
3000 | 180000 | 7.9 | 1.2 | 0.5 |
3500 | 210000 | 9.2 | 1.7 | 0.7 |
4000 | 240000 | 10.5 | 2.1 | 0.9 |
4500 | 270000 | 11.8 | 2.6 | 1.1 |
5000 | 300000 | 13.1 | 3.2 | 1.4 |
5500 | 330000 | 14.4 | 3.8 | 1.7 |
6000 | 360000 | 15.7 | 4.5 | 2.0 |
6500 | 490000 | 17.0 | 5.2 | 2.3 |
7000 | 420000 | 18.3 | 6.0 | 2.6 |
Velocity (ft/sec) |
500 | 30000 | 1.0 | 0.02 | 0.01 |
750 | 45000 | 1.5 | 0.05 | 0.02 |
1000 | 60000 | 2.0 | 0.08 | 0.04 |
1250 | 75000 | 2.5 | 0.1 | 0.05 |
1500 | 90000 | 3.0 | 0.2 | 0.08 |
2000 | 120000 | 4.0 | 0.3 | 0.1 |
2500 | 150000 | 5.0 | 0.5 | 0.2 |
3000 | 180000 | 6.0 | 0.6 | 0.3 |
3500 | 210000 | 7.0 | 0.9 | 0.4 |
4000 | 240000 | 8.0 | 1.1 | 0.5 |
4500 | 270000 | 9.0 | 1.4 | 0.6 |
5000 | 300000 | 10.0 | 1.7 | 0.7 |
5500 | 330000 | 11.0 | 2.0 | 0.9 |
6000 | 360000 | 12.0 | 2.3 | 1.0 |
6500 | 490000 | 13.0 | 2.7 | 1.2 |
7000 | 420000 | 14.0 | 3.1 | 1.3 |
7500 | 450000 | 15.0 | 3.5 | 1.5 |
8000 | 480000 | 16.0 | 4.0 | 1.7 |
8500 | 510000 | 17.0 | 4.4 | 1.9 |
9000 | 540000 | 18.0 | 4.9 | 2.1 |
Pressure loss values can be calculated with the Hazen-Williams Equation or the Darcy-Weisbach Formula.
Standard dimensions and weight of PVC - Polyvinyl Chloride - and CPVC - Chlorinated Polyvinyl Chloride. -
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series. -
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes. -
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports. -
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452. -
Equivalent Length Method - Minor Pressure Loss in Piping Systems
Calculate minor pressure loss in piping systems with the Equivalent Pipe Length Method. -
Hot Water Systems - Equivalent Length vs. Fittings Resistance
Equivalent length of fittings like bends, returns, tees and valves in hot water heating systems - equivalent length in feet and meter. -
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161. -
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports. -
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe. -
Maximum operating and required burst pressure of PVC - Polyvinyl Chloride - pipe fittings. -
Calculate temperature expansion and contraction in PVC piping systems. -
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches. -
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40. -
Water Flow - Max. Delivery Velocities vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
