Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
CTS (Copper Tube Size) and CPVC1) (Chlorinated Poly Vinyl Chloride) tubes according ASTM D2846 Standard Specification for Chlorinated Poly(Vinyl Chloride) (CPVC) Plastic Hot- and Cold-Water Distribution Systems:
Size Nominal (inches) | Outside Diameter (inches) | Wall Thickness SDR 11 (inches) | Aprox. Weight (lb/ft) |
½ | 0.625 | 0.060 - 0.080 | 0.085 |
¾ | 0.875 | 0.080 - 0.100 | 0.140 |
1 | 1.125 | 0.102 - 0.122 | 0.218 |
1¼ | 1.375 | 0.125 - 0.145 | 0.330 |
1½ | 1.625 | 0.148 - 0.168 | 0.460 |
2 | 2.125 | 0.193 - 0.216 | 0.790 |
1) Chlorinated Poly Vinyl Chloride (CPVC) is a thermoplastic pipe and fitting material made with CPVC compounds meeting the requirements of ASTM Class 23447 as defined in ASTM D1784 Standard Specification for Rigid Poly(Vinyl Chloride) (PVC) Compounds and Chlorinated Poly(Vinyl Chloride) (CPVC) Compounds.
CPVC applications are for potable water distribution, corrosive fluid handling in industry, and fire suppression systems.
- 1 inch = 25.4 mm
- PVC and CPVC Pipes - Schedule 40 & 80 according ASTM D1785 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe, Schedules 40, 80, and 120
Dimensions of Pipes and Tubes
Pipe, tube and fittings sizes and dimensions. Inside and outside diameters, weights and more. -
Piping Codes and Standards
Standard dimensions and weight of PVC - Polyvinyl Chloride - and CPVC - Chlorinated Polyvinyl Chloride. -
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products. -
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports. -
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems. -
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings. -
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes. -
CTS - Copper Tube Sizes - Dimensions used in Plumbing
Copper tube sizes used in plumbing. -
Pressure loss (bar/100 m) and velocy in PE, PEH or PVC pipes with water flow. -
Plastic Pipes - Friction Head Loss vs. Water Flow
Friction head loss (ft/100 ft) vs. water flow in plastic pipes like PVC, PP, PE or PEH. -
Piping materials like ABS, PE, PVC, CPVC, PB, PP and SR and pressure and operating temperature limits. -
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports. -
Maximum operating and required burst pressure of PVC - Polyvinyl Chloride - pipe fittings. -
Calculate temperature expansion and contraction in PVC piping systems. -
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40. -
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches. -
Thermal expansion of PVC, CPVC, Carbon and Stainless Steel and Fiberglass pipes. -
