PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Friction loss and flow velocities in PVC and CPVC pipes Schedule 40 with water are indicated in the table below. The table can be used for pipes in other thermoplastic materials where the inner diameter corresponds to PVC Pipe
Schedule 40.
- 1 ft (foot) = 0.3048 m
- 1 ft/s = 0.3048 m/s
- 1 gal (US)/min = 6.30888×10-5 m3/s = 0.227 m3/h = 0.0631 dm3(liter)/s = 2.228×10-3 ft3/s = 0.1337 ft3/min
- 1 psi/100 ft = 2.3 ftH2O/100 ft = 2262 mmH2O/100 m = 22.6 kPa/100 m
Note! Velocities should not exceed 5 feet per second.
The values can be used to calculate minor pressure loss with the Equivalent Pipe Length Method.
| Volume Flow (gal/min) | Volume Flow (gal/hr) | Velocity (ft/sec) | Friction Head (ftH2O/100 ft) | Friction Loss (psi/100 ft) |
| 1 | 60 | 1.1 | 2.1 | 0.9 |
| 2 | 120 | 2.3 | 4.2 | 1.8 |
| 5 | 300 | 5.6 | 23.4 | 10.5 |
| 7 | 420 | 7.9 | 43.1 | 18.6 |
| 10 | 600 | 11.3 | 82.0 | 35.5 |
| Volume Flow (gal/min) | Volume Flow (gal/hr) | Velocity (ft/sec) | Friction Head (ft/100 ft) | Friction Loss (psi/100 ft) |
| 1 | 60 | 0.6 | 0.5 | 0.2 |
| 2 | 120 | 1.3 | 1.0 | 0.4 |
| 5 | 300 | 3.2 | 5.7 | 2.5 |
| 7 | 420 | 4.4 | 10.5 | 4.6 |
| 10 | 600 | 6.3 | 20.0 | 8.7 |
| 15 | 900 | 9.5 | 42.5 | 18.4 |
| 20 | 1200 | 12.7 | 72.3 | 31.3 |
| 2 | 120 | 0.8 | 0.6 | 0.2 |
| 5 | 300 | 1.9 | 1.7 | 0.8 |
| 7 | 420 | 2.7 | 3.2 | 1.4 |
| 10 | 600 | 3.9 | 6.0 | 2.6 |
| 15 | 900 | 5.8 | 12.8 | 5.5 |
| 20 | 1200 | 7.7 | 21.8 | 9.4 |
| 25 | 1500 | 9.7 | 32.9 | 14.2 |
| 30 | 1800 | 11.6 | 46.1 | 20.0 |
| 2 | 120 | 0.4 | 0.1 | 0.1 |
| 5 | 300 | 1.1 | 0.4 | 0.2 |
| 7 | 420 | 1.6 | 0.8 | 0.4 |
| 10 | 600 | 2.2 | 1.6 | 0.7 |
| 15 | 900 | 3.3 | 3.3 | 1.4 |
| 20 | 1200 | 4.4 | 5.6 | 2.4 |
| 25 | 1500 | 5.5 | 8.5 | 3.7 |
| 30 | 1800 | 6.6 | 11.9 | 5.1 |
| 35 | 2100 | 7.7 | 15.8 | 6.8 |
| 40 | 2400 | 8.8 | 20.2 | 8.7 |
| 45 | 2700 | 9.9 | 25.1 | 10.9 |
| 50 | 3000 | 11.1 | 30.5 | 13.2 |
| 2 | 120 | 0.3 | 0.1 | 0.03 |
| 5 | 300 | 0.8 | 0.2 | 0.1 |
| 7 | 420 | 1.1 | 0.4 | 0.2 |
| 10 | 600 | 1.6 | 0.7 | 0.3 |
| 15 | 900 | 2.4 | 1.5 | 0.7 |
| 20 | 1200 | 3.2 | 2.6 | 1.1 |
| 25 | 1500 | 4.0 | 4.0 | 1.7 |
| 30 | 1800 | 4.9 | 5.5 | 2.4 |
| 35 | 2100 | 5.7 | 7.4 | 3.2 |
| 40 | 2400 | 6.5 | 9.4 | 4.1 |
| 45 | 2700 | 7.3 | 11.7 | 5.1 |
| 50 | 3000 | 8.1 | 14.3 | 6.2 |
| 60 | 3600 | 9.7 | 20.0 | 8.7 |
| 5 | 300 | 0.5 | 0.07 | 0.03 |
| 7 | 420 | 0.7 | 0.1 | 0.05 |
| 10 | 600 | 1.0 | 0.2 | 0.09 |
| 15 | 900 | 1.5 | 0.5 | 0.2 |
| 20 | 1200 | 2.0 | 0.8 | 0.3 |
| 25 | 1500 | 2.4 | 1.2 | 0.5 |
| 30 | 1800 | 2.9 | 1.6 | 0.7 |
| 35 | 2100 | 3.4 | 2.2 | 0.9 |
| 40 | 2400 | 3.9 | 2.8 | 1.2 |
| 45 | 2700 | 4.4 | 3.4 | 1.5 |
| 50 | 3000 | 4.9 | 4.2 | 1.8 |
| 60 | 3600 | 5.9 | 5.8 | 2.5 |
| 70 | 4200 | 6.8 | 7.8 | 3.4 |
| 75 | 4500 | 7.3 | 8.8 | 3.8 |
| 80 | 4800 | 7.8 | 9.9 | 4.3 |
| 90 | 5400 | 8.8 | 12.4 | 5.4 |
| 100 | 6000 | 9.8 | 15.0 | 6.5 |
| 5 | 300 | 0.3 | 0.04 | 0.02 |
| 7 | 420 | 0.5 | 0.05 | 0.02 |
| 10 | 600 | 0.7 | 0.1 | 0.04 |
| 15 | 900 | 1.0 | 0.2 | 0.08 |
| 20 | 1200 | 1.4 | 0.3 | 0.1 |
| 25 | 1500 | 1.7 | 0.5 | 0.2 |
| 30 | 1800 | 2.1 | 0.7 | 0.3 |
| 35 | 2100 | 2.4 | 0.9 | 0.4 |
| 40 | 2400 | 2.7 | 1.2 | 0.5 |
| 45 | 2700 | 3.1 | 1.4 | 0.6 |
| 50 | 3000 | 3.4 | 1.8 | 0.8 |
| 60 | 3600 | 4.1 | 2.5 | 1.1 |
| 70 | 4200 | 4.8 | 3.3 | 1.4 |
| 75 | 4500 | 5.1 | 3.7 | 1.6 |
| 80 | 4800 | 5.5 | 4.2 | 1.8 |
| 90 | 5400 | 6.2 | 5.2 | 2.3 |
| 100 | 6000 | 6.8 | 6.3 | 2.7 |
| 125 | 7500 | 8.6 | 9.6 | 4.2 |
| 150 | 9000 | 10.3 | 13.4 | 5.8 |
| 5 | 300 | 0.2 | 0.02 | 0.01 |
| 7 | 420 | 0.3 | 0.02 | 0.01 |
| 10 | 600 | 0.4 | 0.03 | 0.01 |
| 15 | 900 | 0.7 | 0.07 | 0.03 |
| 20 | 1200 | 0.9 | 0.1 | 0.05 |
| 25 | 1500 | 1.1 | 0.2 | 0.07 |
| 30 | 1800 | 1.3 | 0.2 | 0.1 |
| 35 | 2100 | 1.6 | 0.3 | 0.1 |
| 40 | 2400 | 1.8 | 0.4 | 0.2 |
| 45 | 2700 | 2.0 | 0.5 | 0.2 |
| 50 | 3000 | 2.2 | 0.6 | 0.3 |
| 60 | 3600 | 2.7 | 0.9 | 0.4 |
| 70 | 4200 | 3.1 | 1.1 | 0.5 |
| 75 | 4500 | 3.3 | 1.3 | 0.6 |
| 80 | 4800 | 3.5 | 1.4 | 0.6 |
| 90 | 5400 | 4.0 | 1.8 | 0.8 |
| 100 | 6000 | 4.4 | 2.2 | 0.9 |
| 125 | 7500 | 5.5 | 3.3 | 1.4 |
| 150 | 9000 | 6.6 | 4.6 | 2.0 |
| 175 | 10500 | 7.7 | 6.2 | 2.7 |
| 200 | 12000 | 8.8 | 7.9 | 3.4 |
| 250 | 15000 | 11.0 | 11.9 | 5.2 |
| 20 | 1200 | 0.5 | 0.03 | 0.01 |
| 25 | 1500 | 0.6 | 0.04 | 0.02 |
| 30 | 1800 | 0.8 | 0.06 | 0.03 |
| 35 | 2100 | 0.9 | 0.08 | 0.04 |
| 40 | 2400 | 1.0 | 0.1 | 0.05 |
| 45 | 2700 | 1.2 | 0.1 | 0.06 |
| 50 | 3000 | 1.3 | 0.2 | 0.07 |
| 60 | 3600 | 1.5 | 0.2 | 0.1 |
| 70 | 4200 | 1.8 | 0.3 | 0.1 |
| 75 | 4500 | 1.9 | 0.3 | 0.2 |
| 80 | 4800 | 2.1 | 0.4 | 0.2 |
| 90 | 5400 | 2.3 | 0.5 | 0.2 |
| 100 | 6000 | 2.6 | 0.6 | 0.3 |
| 125 | 7500 | 3.2 | 0.9 | 0.4 |
| 150 | 9000 | 3.8 | 1.2 | 0.5 |
| 175 | 10500 | 4.5 | 1.6 | 0.7 |
| 200 | 12000 | 5.1 | 2.1 | 0.9 |
| 250 | 15000 | 6.4 | 3.2 | 1.4 |
| 300 | 18000 | 7.7 | 4.4 | 1.9 |
| 350 | 21000 | 9.0 | 5.9 | 2.6 |
| 400 | 24000 | 10.2 | 7.5 | 3.3 |
| 30 | 1800 | 0.5 | 0.02 | 0.01 |
| 35 | 2100 | 0.6 | 0.03 | 0.01 |
| 40 | 2400 | 0.7 | 0.03 | 0.01 |
| 45 | 2700 | 0.7 | 0.04 | 0.02 |
| 50 | 3000 | 0.8 | 0.05 | 0.02 |
| 60 | 3600 | 1.0 | 0.07 | 0.03 |
| 70 | 4200 | 1.1 | 0.1 | 0.04 |
| 75 | 4500 | 1.2 | 0.1 | 0.05 |
| 80 | 4800 | 1.3 | 0.1 | 0.06 |
| 90 | 5400 | 1.5 | 0.2 | 0.07 |
| 100 | 6000 | 1.6 | 0.2 | 0.08 |
| 125 | 7500 | 2.0 | 0.3 | 0.1 |
| 150 | 9000 | 2.4 | 0.4 | 0.2 |
| 175 | 10500 | 2.8 | 0.5 | 0.2 |
| 200 | 12000 | 3.3 | 0.7 | 0.3 |
| 250 | 15000 | 4.1 | 1.1 | 0.5 |
| 300 | 18000 | 4.9 | 1.5 | 0.6 |
| 350 | 21000 | 5.7 | 2.0 | 0.9 |
| 400 | 24000 | 6.5 | 2.5 | 1.1 |
| 450 | 27000 | 7.3 | 3.1 | 1.3 |
| 500 | 30000 | 8.1 | 3.7 | 1.6 |
| 50 | 3000 | 0.6 | 0.02 | 0.01 |
| 60 | 3600 | 0.7 | 0.03 | 0.01 |
| 70 | 4200 | 0.8 | 0.04 | 0.02 |
| 75 | 4500 | 0.8 | 0.05 | 0.02 |
| 80 | 4800 | 0.9 | 0.05 | 0.02 |
| 90 | 5400 | 1.0 | 0.06 | 0.03 |
| 100 | 6000 | 1.1 | 0.08 | 0.04 |
| 125 | 7500 | 1.4 | 0.1 | 0.05 |
| 150 | 9000 | 1.7 | 0.2 | 0.07 |
| 175 | 10500 | 2.0 | 0.2 | 0.1 |
| 200 | 12000 | 2.3 | 0.3 | 0.1 |
| 250 | 15000 | 2.8 | 0.4 | 0.2 |
| 300 | 18000 | 3.4 | 0.6 | 0.3 |
| 350 | 21000 | 3.9 | 0.8 | 0.3 |
| 400 | 24000 | 4.5 | 1.0 | 0.4 |
| 450 | 27000 | 5.1 | 1.3 | 0.6 |
| 500 | 30000 | 5.6 | 1.5 | 0.7 |
| 750 | 45000 | 8.4 | 3.3 | 1.4 |
| 1000 | 60000 | 11.2 | 5.5 | 2.4 |
| 100 | 6000 | 0.7 | 0.03 | 0.01 |
| 125 | 7500 | 0.8 | 0.04 | 0.02 |
| 150 | 9000 | 1.0 | 0.04 | 0.02 |
| 175 | 10500 | 1.1 | 0.06 | 0.02 |
| 200 | 12000 | 1.3 | 0.07 | 0.03 |
| 250 | 15000 | 1.6 | 0.1 | 0.05 |
| 300 | 18000 | 1.9 | 0.2 | 0.07 |
| 350 | 21000 | 2.3 | 0.2 | 0.09 |
| 400 | 24000 | 2.6 | 0.3 | 0.1 |
| 450 | 27000 | 2.9 | 0.3 | 0.1 |
| 500 | 30000 | 3.2 | 0.4 | 0.2 |
| 750 | 45000 | 4.9 | 0.9 | 0.4 |
| 1000 | 60000 | 6.5 | 1.5 | 0.6 |
| 1250 | 75000 | 8.1 | 2.2 | 1.0 |
| 1500 | 90000 | 9.7 | 3.1 | 1.3 |
| 200 | 12000 | 0.8 | 0.03 | 0.01 |
| 250 | 15000 | 1.0 | 0.04 | 0.02 |
| 300 | 18000 | 1.2 | 0.05 | 0.02 |
| 350 | 21000 | 1.4 | 0.07 | 0.03 |
| 400 | 24000 | 1.6 | 0.09 | 0.04 |
| 450 | 27000 | 1.9 | 0.1 | 0.05 |
| 500 | 30000 | 2.1 | 0.1 | 0.06 |
| 750 | 45000 | 3.1 | 0.3 | 0.1 |
| 1000 | 60000 | 4.1 | 0.5 | 0.2 |
| 1250 | 75000 | 5.1 | 0.7 | 0.3 |
| 1500 | 90000 | 6.2 | 1.0 | 0.4 |
| 2000 | 120000 | 8.2 | 1.7 | 0.7 |
| 2500 | 150000 | 10.3 | 2.6 | 1.1 |
| 350 | 21000 | 1 | 0.03 | 0.01 |
| 400 | 24000 | 1.2 | 0.04 | 0.02 |
| 450 | 27000 | 1.3 | 0.05 | 0.02 |
| 500 | 30000 | 1.5 | 0.06 | 0.03 |
| 750 | 45000 | 2.2 | 0.1 | 0.05 |
| 1000 | 60000 | 2.9 | 0.2 | 0.09 |
| 1250 | 75000 | 3.6 | 0.3 | 0.1 |
| 1500 | 90000 | 4.3 | 0.4 | 0.2 |
| 2000 | 120000 | 5.8 | 0.7 | 0.3 |
| 2500 | 150000 | 7.2 | 1.1 | 0.5 |
| 3000 | 180000 | 8.7 | 1.6 | 0.7 |
| 3500 | 210000 | 10.1 | 2.1 | 0.9 |
| 4000 | 240000 | 11.1 | 2.7 | 1.2 |
| 500 | 30000 | 1.2 | 0.03 | 0.01 |
| 750 | 45000 | 1.8 | 0.07 | 0.03 |
| 1000 | 60000 | 2.4 | 0.1 | 0.05 |
| 1250 | 75000 | 3.0 | 0.2 | 0.08 |
| 1500 | 90000 | 3.6 | 0.3 | 0.1 |
| 2000 | 120000 | 4.7 | 0.5 | 0.2 |
| 2500 | 150000 | 5.9 | 0.7 | 0.3 |
| 3000 | 180000 | 7.1 | 1.0 | 0.4 |
| 3500 | 210000 | 8.3 | 1.3 | 0.6 |
| 4000 | 240000 | 9.5 | 1.7 | 0.7 |
| 4500 | 270000 | 10.7 | 2.1 | 0.9 |
| 5000 | 300000 | 11.9 | 2.5 | 1.1 |
| 5500 | 330000 | 13.1 | 3.0 | 1.3 |
| 6000 | 360000 | 14.2 | 3.6 | 1.5 |
| 6500 | 390000 | 15.4 | 4.1 | 1.8 |
| 7000 | 420000 | 16.6 | 4.7 | 2.0 |
| 7500 | 450000 | 17.8 | 5.4 | 2.3 |
| 500 | 30000 | 0.9 | 0.02 | 0.01 |
| 750 | 45000 | 1.4 | 0.04 | 0.02 |
| 1000 | 60000 | 1.8 | 0.07 | 0.03 |
| 1250 | 75000 | 2.3 | 0.1 | 0.04 |
| 1500 | 90000 | 2.7 | 0.1 | 0.06 |
| 2000 | 120000 | 3.6 | 0.2 | 0.1 |
| 2500 | 150000 | 4.5 | 0.4 | 0.2 |
| 3000 | 180000 | 5.5 | 0.5 | 0.2 |
| 3500 | 210000 | 6.4 | 0.7 | 0.3 |
| 4000 | 240000 | 7.3 | 0.9 | 0.4 |
| 4500 | 270000 | 8.2 | 1.1 | 0.5 |
| 5000 | 300000 | 9.1 | 1.3 | 0.6 |
| 5500 | 330000 | 10.0 | 1.6 | 0.7 |
| 6000 | 360000 | 10.9 | 1.9 | 0.8 |
| 6500 | 390000 | 11.8 | 2.2 | 0.9 |
| 7000 | 420000 | 12.7 | 2.5 | 1.1 |
| 7500 | 450000 | 13.6 | 2.8 | 1.2 |
| 8000 | 480000 | 14.5 | 3.2 | 1.4 |
| 8500 | 510000 | 14.4 | 3.5 | 1.5 |
| 9000 | 540000 | 16.5 | 3.9 | 1.7 |
| 9500 | 570000 | 17.3 | 4.3 | 1.9 |
| 10000 | 600000 | 18.2 | 4.8 | 2.1 |
Pressure loss values can be calculated with the Hazen-Williams Equation or the Darcy-Weisbach Formula.
