Water Flow - Max. Delivery Velocities vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
As a rule of thumb the following velocities can be used in design of piping and pumping systems for water:
NPSMax. Delivery Velocity
inchesmmm/sft/s
1 25 1 3.5
2 50 1.1 3.6
3 75 1.15 3.8
4 100 1.25 4
6 150 1.5 4.7
8 200 1.75 5.5
10 250 2 6.5
12 300 2.65 8.5
More about Water Systems, Pumps or Piping Systems.
Water pipes - maximum recommended flow velocity
  • Piping Systems
  • Pumps
  • Water Systems
  • The Engineering ToolBox (2003). Water Flow - Max. Delivery Velocities vs. Pipe Size. [online] Available at: https://www.engineeringtoolbox.com/pump-delivery-flow-velocity-water-d_232.html [Accessed Day Month Year].
