Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
Turbulent or laminar flow is determined by the dimensionless Reynolds Number which is important when analyzing fluid flow where there is a substantial velocity gradient (i.e. shear). The Reynolds number indicates the relative significance of the viscous effect compared to the inertia effect and the number is proportional to the inertial force divided by the viscous force.
The flow is
  • laminar when Re < 2300
  • transient when 2300 < Re < 4000
  • turbulent when 4000 < Re
Reynolds Number for one liter of water at approximately 20 oC (68 oF) flowing through pipes of different dimensions:
Pipe Size
(inches)11 1/223468101218
(mm)25405075100150200250300450
Reynolds number with
1 liter/min
835 550 420 280 210 140 105 85 70 46
1 gal/min
3180 2090 1600 1060 780 570 400 320 265 175
Note that the water viscosity varies with temperature.
  • the kinematic viscosity of water at 20 oC - used to calculate the table above - is 1.004·10-6 m2/s
  • at 0 oC the kinematic viscosity is 1.787·10-6 m2/s - the Reynolds values in the table above must be multiplicated with 1.004 / 1.787 = 0.56
  • at 100 oC the kinematic viscosity is 0.29·10-6 m2/s - the values in the table above must be multiplicated with 1.004 / 0.29 = 3.46
