Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
As a rule of thumb the following velocities can be used in design of piping and pumping systems for light oil transport:
Light Oil Pumping - Recommended Flow Velocities
Pipe DimensionLight Oil Velocity
inchesmmm/sft/s
1 25 1 3.5
2 50 1.1 3.6
3 75 1.15 3.8
4 100 1.25 4
6 150 1.5 4.7
8 200 1.75 5.5
10 250 2 6.5
12 300 2 6.5
  • Piping Systems
  • Pumps
  • The Engineering ToolBox (2003). Light Oil Pumping - Flow Velocities. [online] Available at: https://www.engineeringtoolbox.com/pump-delivery-flow-velocity-oil-d_233.html [Accessed Day Month Year].
