Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
As a rule of thumb - velocities that can be used in design of piping and pumping systems for viscous liquids:
Pipe DimensionDelivery Velocity
inchesmmm/sft/s
1 25 1 3.5
2 50 1.1 3.6
3 75 1.1 3.7
4 100 1.15 3.8
6 150 1.2 3.9
8 200 1.2 4
10 250 1.3 4.5
12 300 1.4 4.5
  • Piping Systems
  • Pumps
  • The Engineering ToolBox (2003). Viscous Liquids - Max. Delivery Flow Velocities. [online] Available at: https://www.engineeringtoolbox.com/pump-delivery-flow-velocity-viscous-fluid-d_235.html [Accessed Day Month Year].
