Melting and Freezing Points
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Arsenic - Melting Points of Binary Eutectic Alloys
As - Arsenic - binary eutectic alloys and their melting points.
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Elements - Melting Points
Melting points of elements.
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Glycerine - Boiling and Freezing Points
Boiling and freezing points of glycerine aqueous solutions.
Hydrocarbons - Physical Data
Hydrocarbons - Melting Point vs. Molecular Weight
Calculate melting point of hydrocarbons from molecular weight (molar mass).
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Liquids - Freezing and Melting Points
Common fluids and their freezing and melting points.
Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units.
Metal Alloys - Melting Points
Alloys and their melting points.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Oils - Melting points
Common oils from animals or plants and their melting points.
Organic Nitrogen Compounds - Physical Data
Boiling and melting points of amines, diamines, pyrroles, pyridines, piperidines and quinolines shown together with their molecular structures, as well as molweights and density.
Organic Sulfur Compounds - Physical Data
Boiling and melting points of thoils, sulfides, disulfides and thiophenes shown together with molecular structures, as well as molweights and density.
Salt Hydrates - Melting points and Latent Melting Energy
Melting points and latent energy of salt hydrates.
Silver Binary Eutectic Alloys - Melting Points
Ag - Silver - binary eutectic alloys and melting points.
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
