Tabulated values and viscosity units conversion are given below the figures.
Benzene phase diagram
Online Liquid Benzene Viscosity Calculator
The calculator below can be used to estimate liquid benzene dynamic or kinematic viscosity at given temperatures. The calculator gives the viscosity at saturation pressure. For most practicle issues this can be used for liquid benzene at any pressure up to the critical point (289°C, 49 bara or 552°F, 712 psia)
See also other properties of Benzene at varying temperature and pressure: Density and specific weight , and Thermophysical properties at standard conditions , as well as dynamic and kinematic viscosity of air , ammonia , butane , carbon dioxide , ethane , ethanol , ethylene , methane , methanol , nitrogen , oxygen , propane and water .
Dynamic viscosity of benzene at gas-liquid equilibrium pressure:
Benzene dynamic viscosity equlibrium C
Benzene dynamic viscosity equlibrium F
Kinematic viscosity of benzene at gas-liquid equilibrium pressure:
Benzene kinematic viscosity equlibrium C
Benzene kinematic viscosity equlibrium F
Dynamic (absolute) and kinematic viscosity of benzene at given temperatures and pressures, SI and Imperial units:
For full table Dynamic and Kinematic Viscosity - rotate the screen!
State Temperature Pressure Dynamic (Absolute) Viscosity Kinematic viscosity
[K] [°C] [°F] [bara] [psia] [μPa s] [cP] [lbf s/ft2*10-6 ] [lbm /ft s*10-6 ] [lbm /ft h] [cSt],
[m2/s*10-6 ]
[ft2/s*10-6 ]
Liquid at
equilibrium
278.70 5.55 41.99 0.0480 0.696 828.1 0.8281 17.30 556.5 2.003 0.9266 9.974
280 6.9 44.3 0.0515 0.747 810.4 0.8104 16.93 544.6 1.960 0.9082 9.775
300 26.9 80.3 0.138 2.00 596.2 0.5962 12.45 400.6 1.442 0.6841 7.364
320 46.9 116 0.321 4.65 452.5 0.4525 9.451 304.1 1.095 0.5324 5.730
340 66.9 152 0.661 9.59 352.7 0.3527 7.366 237.0 0.8532 0.4258 4.583
360 86.9 188 1.24 18.0 281.1 0.2811 5.871 188.9 0.6800 0.3488 3.755
380 107 224 2.16 31.3 228.4 0.2284 4.770 153.5 0.5525 0.2918 3.141
400 127 260 3.53 51.2 188.5 0.1885 3.937 126.7 0.4560 0.2485 2.674
450 177 350 9.72 141 122.5 0.1225 2.558 82.32 0.2963 0.1768 1.904
500 227 440 21.7 314 82.34 0.08234 1.720 55.33 0.1992 0.1349 1.452
550 277 530 42.1 611 52.37 0.05237 1.094 35.19 0.1267 0.1124 1.210
Gas at
equilibrium
278.7 5.6 42.0 0.0480 0.696 6.960 0.00696 0.1454 4.677 0.01684 42.88 461.6
280 6.9 44.3 0.051 0.747 6.994 0.006994 0.1461 4.700 0.01692 40.36 434.4
300 26.9 80.3 0.138 2.00 7.509 0.007509 0.1568 5.046 0.01816 17.22 185.3
320 46.9 116 0.321 4.65 8.031 0.008031 0.1677 5.397 0.01943 8.404 90.46
340 66.9 152 0.661 9.59 8.564 0.008564 0.1789 5.755 0.02072 4.574 49.24
360 86.9 188 1.24 18.0 9.113 0.009113 0.1903 6.124 0.02205 2.699 29.06
380 107 224 2.16 31.3 9.685 0.009685 0.2023 6.508 0.02343 1.708 18.38
400 127 260 3.53 51.2 10.3 0.0103 0.2151 6.921 0.02492 1.144 12.31
450 177 350 9.72 141 12.22 0.01222 0.2552 8.211 0.02956 0.5029 5.413
500 227 440 21.7 314 15.62 0.01562 0.3262 10.50 0.03779 0.2711 2.918
550 277 530 42.1 611 25.18 0.02518 0.5259 16.92 0.06091 0.1675 1.803
Liquid 298 25 77 1 14.5 604 0.604 12.6 406 1.46 0.691 7.44
323 50 122 1 14.5 436 0.436 9.11 293 1.05 0.515 5.54
348 75 167 1 14.5 335 0.335 7.00 225 0.810 0.409 4.40
Unit conversion:
Viscosity, Dynamic (Absolute)
  • 1 reyn = 6894.76 Pa s
Viscosity, Kinematic
  • Thermodynamics
  • Viscosities
  • The Engineering ToolBox (2018). Benzene - Dynamic and Kinematic Viscosity vs. Temperature and Pressure. [online] Available at: https://www.engineeringtoolbox.com/benzene-benzol-dynamic-kinematic-viscosity-temperature-d_2073.html [Accessed Day Month Year].
