Centrifugal Pumps - Viscosity Influence
Hydrodynamic losses through pumps depends on fluid viscosities.
When a more viscous fluid is handled by a centrifugal pump
  • brake horsepower requirement increases
  • the head generated is reduced
  • capacity is reduced
  • efficiency of pump is reduced and the Best Efficiency Point - BEP - is moved
Centrifugal pumps and influence of fluid viscosity
The head, flow and capacity with fluids with other viscosities than used in the original documentation can be modified with coefficients.
Flow
qv = cq q                                (1)
qv = flow compensated for viscosity (m3/h, gpm)
cq = viscosity flow coefficient
q = original flow according pump curve (m3/h, gpm)
Head
hv = ch h                               (2)
hv = head compensated for viscosity (m, ft)
ch = viscosity head coefficient
h = original head according pump curve (m, ft)
Efficiency
μv = cμ μ                             (3)
μv = effciency compensated for viscosity
cμ = viscosity efficiency coefficient
μ = original efficiency according pump curve
Power - SI units
Pv = qv hv ρv g / (3.6 106  μv)                            (4)
Pv = power compensated for viscosity (kW)
ρv = density of viscous fluid (kg/m3)
Power - Imperial units
Pv = qv hv SG / (3960 μv)                              (5)
Pv = power compensated for viscosity (bhp)
SG = specific gravity of viscous fluid
  • Pumps
  • Viscosities
  • The Engineering ToolBox (2006). Centrifugal Pumps - Viscosity Influence. [online] Available at: https://www.engineeringtoolbox.com/centrifugal-pumps-viscosity-d_670.html [Accessed Day Month Year].
