Tabulated values of methanol viscosity and viscosity units conversion are given below the figures.
Online Methanol Viscosity Calculator
The calculator below can be used to estimate dynamic or kinematic viscosity of liquid methanol at given temperatures. The atmospheric boiling point of methanol is 64.15 °C (147.47 °F), and methanol must be pressurized to be present as liquid above that temperature.
See also other properties of Methanol at varying temperature and pressure: Density and specific weight and Specific Heat (Heat Capacity) , and Thermophysical properties at standard conditions ,
as well as dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethane , ethanol , ethylene , methane , nitrogen , oxygen , propane and water .
Dynamic and kinematic viscosity of liquid methanol at varying temperature:
Methanol viscosity liquid C
Methanol viscosity liquid F
The atmospheric boiling point of methanol is 64.15 °C (147.47 °F), and methanol must therefore be pressurized to be present as liquid above that temperature.
Dynamic (absolute) and kinematic viscosity of liquid methanol at given temperatures and pressures, SI and Imperial units:
State Temperature Dynamic (Absolute) Viscosity Kinematic viscosity
[K] [°C] [°F] [μPa s] [cP],
[mPa s]
[x10-6 lbf s/ft2] [x10-6 lbm s/ft s] [lbm /ft h] [cSt],
[x10-6 m2/s]
[x10-6 ft2/s]
Liquid 248.2 -25 -13 1258 1.258 0.02627 0.8453 0.003043 1.508 16.23
273.2 0.0 32 795.0 0.7950 0.01660 0.5342 0.001923 0.9815 10.56
293.2 20 68 594.0 0.5940 0.01241 0.3991 0.001437 0.7500 8.073
298.2 25 77 543.5 0.5435 0.01135 0.3652 0.001315 0.6906 7.434
303.2 30 86 507.0 0.5070 0.01059 0.3407 0.001226 0.6488 6.983
323.2 50 122 392.0 0.3920 0.00819 0.2634 0.000948 0.5142 5.535
348.2 75* 167* 294.0 0.2940 0.00614 0.1976 0.000711 0.4000 4.306
373.2 100* 212* 227.0 0.2270 0.00474 0.1525 0.000549 0.3206 3.451
* The atmospheric boiling point of methanol is 64.15 °C (147.47 °F), and methanol must therefore be pressurized to be present as liquid above that temperature.
Unit conversion:
Viscosity Dynamic, Absolute
  • 1 reyn = 6894.76 Pa s
Viscosity Kinematic
  • Thermodynamics
  • Viscosities
  • The Engineering ToolBox (2018). Methanol - Dynamic and Kinematic Viscosity vs. Temperature and Pressure. [online] Available at: https://www.engineeringtoolbox.com/methanol-dynamic-kinematic-viscosity-temperature-pressure-d_2093.html [Accessed Day Month Year].
