Acoustic Impedance
Specific acoustic impedance is measure of the ability of a medium to transmit sound waves.
It can be expressed as
Z = P / v
= ρ c (1)
Z = acoustic impedance (Pa s/m)
p = sound pressure (Pa)
v = particle velocity (m/s)
ρ = density of medium (kg/m3)
c = velocity of sound (m/s)
The equation express the coupling between the vibrating particles in the medium.
• Acoustics
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Liquids - Speed of Sound
Speed of sound in common fluids like water, glycerol, kerosene and more.
Propagation of Sound Outdoors - Attenuation vs. Distance
The propagation of outdoors sound vs. distance and attenuation.
Solids and Metals - Speed of Sound
Speed of sound in solids and metals like aluminum, brass, concrete and more.
An introduction to the nature of sound with frequencies, wave-lengths and octaves.
Sound Pressure Level
Ultrasonic Doppler and Time of Flight Velocity and Volume Flow Meters
An basic introduction to the ultrasonic Doppler and Time of Flight Flow Meters.
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212°F (0 - 100°C) - Imperial and SI units.
