Measurement of Electrical Power
Electric power in a circuit can be measured with an ammeter (amperemeter) and a voltmeter.
The power can be calculated as
P = U I
= R I2 (1)
P = electric power (W, watts)
U = voltage (V, volt)
I = current (A, ampere)
R = resistance (Ω, ohm)
Example - Power consumption of a circuit with an electric heater
The current in a 230 V household circuit with an electric heater is measured with an ammeter to 8 A. The power consumption can be calculated as
P = (230 V) (8 A)
= 1840 W
Electric Power Calculator
• Electrical
• Measurements and Instrumentation
Measurement and instrumentation strategies.
AC Circuits - Power vs. Voltage and Current
The alternating current In an AC circuit is generated by a sinusoidal voltage source.
Electrical Distribution Systems
Electrical distribution systems commonly used in Europe and USA
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
Electrical Units
Definition of common electrical units - like Ampere, Volt, Ohm, Siemens.
Ohm's Law
The relation between voltage, current and electrical resistance.
Power
Single and Three Phase AC - Electric Current vs. Power
Convert between single phase (120, 240 and 480 Voltage) and three phase (240 and 480 Voltage).
Single Phase Power Equations
Power equations for single phased electrical systems.
Three-Phase Power - Equations
Electrical 3-phase equations.
