Electrical Distribution Systems
TN
  • 3-Phase, 4-Wire 400Y/230 V
  • used in Europe and others
IT
  • 3-Phase, 3-Wire 230 V Wye (No neutral)
  • used in Norway
Three Phase Three Wire Delta
  • used to provide power for three-phase motor loads in industry, and utility power distribution systems
  • voltage typical 240, 400, 480, 600 and higher
277/480V Three Phase Four Wire Wye
  • used in larger US facilities with voltage 277/480. 277 volt is used as single phase for lighting and 480 volt is used for larger loads like HVAC systems
  • in western Canada 347/600V is commonly used
120/240V Three Phase Four Wire Delta
  • used in older manufacturing facilities with mostly three-phase motor loads and some 120 volt single-phase lighting and plug loads
120/240V Single Phase Three Wire
  • grounded neutral system
  • known as the Edison system, split-phase or center-tapped neutral
  • common as residential service in North America
120/208V Three Phase Four Wire Wye
  • the most common commercial building electric service in North America
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
