Infiltration - Heat Losses from Buildings
Estimated heat loss from
- Offices, apartments, hotels ...
- Entrance halls, vestibules ...
- Industrial buildings ...
- Houses ..
- Public buildings ..
by infiltration:
Infiltration rates through various Types of Wall Constructions
Wall Type | Infiltration Rates (cu.ft per foot of crack per hr.) | |||||
Wind Velocity (mph) | ||||||
5 | 10 | 15 | 20 | 25 | 30 | |
Frame Wall with lath and plaster or wallboard | 0.03 | 0.07 | 0.13 | 0.18 | 0.23 | 0.26 |
Brick Wall, 8 1/2" plain | 2 | 4 | 8 | 12 | 19 | 23 |
Brick Wall, 8 1/2" plain with plaster or wallboard | 0.02 | 0.04 | 0.07 | 0.11 | 0.16 | 0.24 |
Brick Wall, 13" plain | 1 | 4 | 7 | 12 | 16 | 21 |
Brick Wall, 13" plain with plaster or wallboard | 0.01 | 0.01 | 0.03 | 0.04 | 0.07 | 0.10 |
• Heating Systems
Building Elements - Heat Loss vs. Thermal Resistivity
Thermal resistance in building elements like walls, floors and roofs above and below the ground.
Heat Loss from Buildings
Overall heat transfer loss from buildings - transmission, ventilation and infiltration.
Heat Transmission Loss through Building Elements
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units.
Natural Draft - Air Flow Volume and Velocity
Air flow - volume and velocity - due to stack or flue effect caused by indoor hot and outdoor cold temperature difference.
Recommended Air Change Rates for Different Room Types
Fresh air (make up air) rquirements - or recommended air change rates (ACH) for typical rooms and buildings like auditoriums, kitchens, churches and more.
Staircase Calculator
Calculate steps, unit rise and run in a staircase.
