Recommended Air Change Rates for Different Room Types
The volume of fresh air (make up air) required for a proper ventilation of a space is determined of the size and the use of the space - typical the no. of persons in the space, if smoking is allowed or not and pollution from processes.
The table below indicates air change rates (air changes per hour) commonly used in different types of rooms and buildings.
- Note! - be aware that it may be necessary to calculate required supply air based on no. of persons in the room or building. More information about required supply air per person can be found here.
Building / Room | Air Change Rate - n - (1/h) |
All spaces in general | min 4 |
Assembly halls | 4 - 6 |
Attic spaces for cooling | 12 - 15 |
Auditoriums | 8 - 15 |
Bakeries | 20 - 30 |
Banks | 4 - 10 |
Barber Shops | 6 - 10 |
Bars | 20 - 30 |
Beauty Shops | 6 - 10 |
Boiler rooms | 15 - 20 |
Bowling Alleys | 10 - 15 |
Cafeterias | 12 - 15 |
Churches | 8 - 15 |
Classrooms | 6 - 20 |
Club rooms | 12 |
Clubhouses | 20 - 30 |
Cocktail Lounges | 20 - 30 |
Computer Rooms | 15 - 20 |
Court Houses | 4 - 10 |
Dance halls | 6 - 9 |
Dental Centers | 8 - 12 |
Department Stores | 6 - 10 |
Dining Halls | 12 -15 |
Dining rooms (restaurants) | 12 |
Dress Shops | 6 - 10 |
Drug Shops | 6 - 10 |
Engine rooms | 4 - 6 |
Factory buildings, ordinary | 2 - 4 |
Factory buildings, with fumes or moisture | 10 - 15 |
Fire Stations | 4 - 10 |
Foundries | 15 - 20 |
Galvanizing plants | 20 - 30 |
Garages repair | 20 - 30 |
Garages storage | 4 - 6 |
Homes, night cooling | 10 - 18 |
Hospital rooms | 4 - 6 |
Jewelry shops | 6 - 10 |
Kitchens | 15 - 60 |
Laundries | 10 - 15 |
Libraries, public | 4 |
Lunch Rooms | 12 -15 |
Luncheonettes | 12 -15 |
Nightclubs | 20 - 30 |
Machine shops | 6 - 12 |
Malls | 6 - 10 |
Medical Centers | 8 - 12 |
Medical Clinics | 8 - 12 |
Medical Offices | 8 - 12 |
Mills, paper | 15 - 20 |
Mills, textile general buildings | 4 |
Mills, textile dye houses | 15 - 20 |
Municipal Buildings | 4 - 10 |
Museums | 12 -15 |
Offices, public | 3 |
Offices, private | 4 |
Paint shops | 10 - 15 |
Paper mills | 15 - 20 |
Photo dark rooms | 10 - 15 |
Pig houses | 6 - 10 |
Police Stations | 4 - 10 |
Post Offices | 4 - 10 |
Poultry houses | 6 - 10 |
Precision Manufacturing | 10 - 50 |
Pump rooms | 5 |
Railroad shops | 4 |
Residences | 1 - 2 |
Restaurants | 8 - 12 |
Retail | 6 - 10 |
School Classrooms | 4 - 12 |
Shoe Shops | 6 - 10 |
Shopping Centers | 6 - 10 |
Shops, machine | 5 |
Shops, paint | 15 - 20 |
Shops, woodworking | 5 |
Substation, electric | 5 - 10 |
Supermarkets | 4 - 10 |
Swimming pools | 20 - 30 |
Textile mills | 4 |
Textile mills dye houses | 15 - 20 |
Town Halls | 4 - 10 |
Taverns | 20 - 30 |
Theaters | 8 - 15 |
Transformer rooms | 10 - 30 |
Turbine rooms, electric | 5 - 10 |
Warehouses | 2 |
Waiting rooms, public | 4 |
Warehouses | 6 - 30 |
Wood-working shops | 8 |
Be aware of local regulations and codes.
Fresh air supply - make up air - to a room based on the table above can be calculated as
q = n V (1)
q = fresh air supply (ft3/h, m3/h)
n = air change rate (h-1)
V = volume of room (ft3, m3)
Example - Fresh Air Supply to a Public Library
The fresh air supply to a public library with volume 1000 m3 can be calculated as
Q = (4 h-1) (1000 m3)
= 4000 m3/h
Air Volume Calculator
Air Change Out Frequency in minutes
The "Air Change Out Frequency" in minutes can be calculated as
nm = 60 / n (2)
nm = Air Change Out Frequency (minutes)
• Ventilation Systems
Air Change Rate
Calculate air change rates - equations in imperial and SI units.
Garage Ventilation
Exhaust ventilation from garages and workshops.
Infiltration - Heat Losses from Buildings
Estimated infiltration heat losses from buildings.
Outdoor Supply Air Rates
Recommended supply air rates of outdoor air - with or without smoking - in rooms like banks, assembly halls, hotels and many more.
Pollution Concentration in Rooms
Concentration of a pollution in a limited space as a room depends on the amount of polluted material spread in the room, supply of fresh air, outlets positions and construction, principles used for supply and outlet from the space.
Staircase Calculator
Calculate steps, unit rise and run in a staircase.
