Hot Water Heating Systems - Flow Temperatures vs. Outside Temperatures
Seasonal effects - outside temperature - and operating boiler temperatures in typical two-pipe forced hot water systems are indicated in the table below:
It is common to design a hot-water heating system for a temperature drop of 20 oC (36 oF) in heating elements and radiators at what is considered as minimum outside design temperatures.
Maximum boiler flow temperature is often set to 80 oC (176 oF) to avoid "burned dust" and accidentally injures on people when touching heaters. Outside design temperature depends on the actual location.
Minimum Outside Design Temperature (oC) | Boiler Flow Temperature (oC) | ||||
Outside Temperature (oC) | |||||
-20 | -10 | 0 | 10 | 20 | |
-20 | 80 | 66 | 51 | 37 | 37 |
-10 | 80 | 58 | 37 | 37 | |
0 | 80 | 37 | 37 | ||
• Heating Systems
Design of Hot Water Heating Systems
Calculate gravity and forced circulating hot water heating systems.
Heating System Flow Rates
Calculate flow rates in heating systems.
Hot Water Expansion Tanks - Sizing
Required hot water expansion volume in open, closed and diaphragm tanks.
Hot Water Heating System Online Design Application
Hot Water Heating System Temperatures vs. Outdoor Temperatures
Hot water heating temperatures adapts to outdoor temperatures.
Pressure loss nomogram for hot water steel pipes.
