Diaphragm Expansion Tanks
Temperature in degrees Fahrenheit and pressure in psig
- initial temperature 50oF
- initial pressure 10 psig
- maximum operating pressure 30 psig
- safety factor aprox. 2
- acceptance factor aprox. 0.5
The diagram below can be used to estimate the tank volume and acceptance volume of a diaphragm expansion tank at low temperatures.
For initial and maximum pressures different from above - multiply the tank size with the a correction factor estimated from the diagram below:
Temperature in degrees Celsius- pressure in kPa
- initial temperature 10oC
- initial pressure 70 kPa
- maximum operating pressure 200 kPa
The diagram below can be used to estimate the tank volume and acceptance volume of a closed expansion tank at low temperatures.
• Heating
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
Closed Expansion Tanks - Volume vs. Temperature and Pressure
Sizing of low temperature closed expansion tanks.
Hot Water Expansion Tanks - Sizing
Required hot water expansion volume in open, closed and diaphragm tanks.
