Closed Expansion Tanks - Volume vs. Temperature and Pressure
Temperatures in degrees Fahrenheit and pressure in psig
  • initial temperature 50 oF
  • initial pressure 10 psig
  • maximum operating pressure 30 psig
  • safety factor aprox. 2
The diagram below can be used to estimate the size of a closed expansion tank at low temperature.
For initial and maximum pressures different from above - multiply the tank size with the a correction factor estimated from the diagram below:
Temperatures in degrees Celsius and pressure in kPa
  • initial temperature 10 oC
  • initial pressure 70 kPa
  • maximum operating pressure 200 kPa
The diagram below can be used to estimate the size of a closed expansion tank at low temperatures.
Heating Systems
Diaphragm Expansion Tanks
Low temperature diaphragm expansion tank sizing - calculate tank volume and acceptance volume.
Hot Water Expansion Tanks - Sizing
Required hot water expansion volume in open, closed and diaphragm tanks.
