Pressure (psig) and temperature (deg F) ratings of A106 Grade B carbon steel pipes - temperatures ranging 100 oF - 750 oF
Non-shock pressure (psig) and temperature ratings for steel pipe flanges and flanged fittings
A survey of one of the most important pressure pipe codes - ASME B31, earlier known as ANSI B31
The working pressure and temperature limits of ASME Code B31.9 - Building Services Piping
Pressure (kPa) and temperature (oC) ratings of ASTM A106, API 5L and ASTM A53 Seamless Carbon Steel Pipes - temperatures ranging -29 oC - 450 oC
Maximum working pressure of carbon steel pipe at temperature 400oF
The theoretic bursting and collapsing values of stainless steel pipes - ASTM A312
Barlows Formula and bursting pressure of pipes and tubes
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105
Maximum working pressure of cast iron pipe fittings - flanged fittings according ANSI B16.1
Maximum working pressure of cast iron pipe fittings - threaded fittings according ANSI B16.4
Liquid volume in partly filled horizontal tanks or pipes
Metric Sizes of copper tubes to BS (British Standard) 2871:1972
Maximum operating and bursting pressures of CPVC - Chlorinated Poly(Vinyl Chloride) - piping systems
Pressure numbers (PN) compared to flange class designations
Flanged fittings and hydrostatic test pressure
Calculation formula spring operated relief valves in liquid systems
ASME/ANSI B16.3 - 1998 - Malleable Iron Threaded Fittings - Pressure-Temperature Ratings
Maximum operating pressure of Polyethylene - PEH - pipes depends on temperature
Polyethylene - PE - pipes and pressure classes
Pipe bends and thrust blocks forces on anchors due to fluid velocity and internal pressure - online resulting force calculator
Solder joints pressure ratings according ASME B16.18
Maximum operating and required burst pressure of PVC - Polyvinyl Chloride - pipe fittings
Boilers 275 to 1500 kW and Safety Valves
Calculation formula pilot operated relief valves in liquid systems
Pressure ratings for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF
It is common to use the "Standard Dimension Ratio" - SDR - as method of rating pressure piping
Normal maximum working pressures for steel tubes- in psi (lb/in2) and kPa (kN/m2)
Allowable stresses in pipe walls for pipes ASTM specification A-53, A-106 and more
Increased temperature derates the strength of thermoplastic piping materials
Theoretical bursting and working pressure wrought steel standard, extra strong and double extra strong pipe
9 11 11
