PN Pressure Ratings for Flanges: Specifications & Standards
Piping Class Ratings based on the ASME B16.5 - Pipe Flanges and Flanged Fittings: NPS 1/2 through NPS 24 Metric/Inch Standard - class and the corresponding ISO 7005 PN (Pression Nominal*) ratings:
| Flange Class | 150 | 300 | 400 | 600 | 900 | 1500 | 2500 |
| Flange Pressure Nominal (PN) | 20 | 50 | 68 | 110 | 150 | 260 | 420 |
* "Pression Nominal" is the French equivalent of Pressure Nominal
"Pression Nominal" is the rating designator followed by a designation number indicating the approximate pressure rating in bars.
- 1 bar = 1×105 Pa (N/m2) = 0.1 N/mm2 = 10,197 kp/m2 = 10.20 m H2O = 0.98692 atm = 14.5038 psi (lbf/in2)
PN ratings do not provide a proportional relationship between different PN numbers, whereas class numbers do. Class numbers are therefore recommended before PN ratings.
Note! The piping rating must follow the pressure-temperature rating of the weakest pressure containing item in the system.
