Steam Radiators and Convectors - Heating Capacities
Steam Heated Radiator
The heat capacity of a steam radiator can be expressed as
H r = q s h s λ r (1)
H r = heat capacity of radiator (kW, Btu/h)
q s = condensate rate (kg/h, lb/h)
h s = latent heat steam (2675 kJ/kg, 970 Btu/lb)
λ r = radiator temperature correction coefficient = 1 for room temperature 70 o F (21 o C) and steam temperature 215 o F (100 o C).
The radiator correction coefficient for other room and steam temperatures can be calculated
λ r = [( (215 o F) - (70 o F) )/(t s - t r )] 1.3 (1b)
t s = average steam temperature ( o F)
t r = room temperature ( o F)
Steam Heated Convector
The heat capacity of a steam heated convector can be expressed as
H c = q s h s λ c (2)
H c = heat capacity of convector (kW, Btu/h)
λ c = convector temperature correction coefficient = 1 for inlet temperature 65 o F (18 o C) and steam temperature 215 o F (100 o C).
The convector correction coefficient for other room and steam temperatures can be calculated
λ = [((215 o F) - (65 o F) )/(t s - t i )] 1.5 (3)
t s = steam temperature ( o F)
t i = inlet temperature ( o F)
• Heating
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
• Steam and Condensate
Air Heating Systems
Air heating buildings - heat supply vs. air flow and temperature.
Convective Heat Transmission - Air Velocity and Air Flow Volume
Hot or cold vertical surfaces generates vertical air flows - calculate air velocity and volume flow.
Cooling and Heating Equations
Heat Emission from Radiators and Heating Panels
The heat emission from a radiator or a heating panel depends on the temperature difference between the radiator and the surrounding air.
Heat Loss from Buildings
Overall heat transfer loss from buildings - transmission, ventilation and infiltration.
Heat Pumps - Performance and Efficiency Ratings
Performance and efficiency rating of heat pumps.
Radiators - Heat Emission
Calculate heat emission from column and panel radiators.
Transmission Heat Loss through Building Elements
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units.
