Radiators - Heat Emission
Heat output from a radiator is determined by the
  • ambient surrounding temperature
  • temperature of the radiator surface
  • surface area of the radiator
The formulas below can be used to estimate the heat emission from radiators where the temperature difference between the radiator surface and the ambient air is 50 oC (inlet water temperature 80 oC, outlet water temperature 60 oC and ambient air 20 oC).
Heat Emission from Column Radiators
The heat emission from a column radiator can roughly be estimated as
P = kc Ve                                            (1)
P = heat emission (W)
kc = 15000 - 17000 - constant for column radiator
Ve = external radiator volume (m3)
Heat Emission from Panel Radiators
The heat emission from a panel radiator can roughly be estimated as
P = 41 kp l (1 + 8 h)                                    (2)
kp = constant for panel radiator
l = radiator length (m)
h = radiator height (m)
Typical panel radiator configuration constants - kp:
  • 3.1 : for a  single panel
  • 4.1 : for a panel - convector
  • 4.9 : for two panels
  • 5.8 : for a panel - convector - panel
  • 7 : for a panel - convector - convector - panel
  • 7.6 : for three panels
  • 8.8 : for a panel - convector - panel - convector - panel
  • 9 : for four panels
Panel Radiator Calculator
Heating Systems
Heat Emission from Radiators and Heating Panels
The heat emission from a radiator or a heating panel depends on the temperature difference between the radiator and the surrounding air.
Heat Loss from Buildings
Overall heat transfer loss from buildings - transmission, ventilation and infiltration.
Hot Water Heating System - Design Procedure
Hot water heating system design procedure with heat loss, boiler rating, heater units and more.
Steam Radiators and Convectors - Heating Capacities
Steam radiators and steam convectors - heating capacities and temperature coefficients.
