Fan Capacity Diagrams
Pressure head as function of air flow volume may be expressed in a diagram like the one below:
  • red lines are pressure heads as function of air volume flow and speed of the fan
  • green lines marked - l - are throttle lines
  • blue lines are power consumption
Pressure and Head
Operation of fans are often expressed in terms of pressure
pt = ps + pd = constant                                          (1)
pt = total pressure (Pa, N/m2)
ps = static pressure (Pa, N/m2)
pd = dynamic pressure (Pa, N/m2)
Dynamic pressure can be expressed as
pd = ρ v2 / 2                                                  (2)
ρ = density of air (kg/m3)
v = flow velocity (m/s)
Head developed can be expressed as
dp = ps2 - ps1 + (v22 - v12) ρ / 2                                                (3)
subscription 1 is the inlet of the fan and subscription 2 is the outlet
Ventilation
Fan Affinity Laws
The affinity laws can be used to calculate resulting volume capacity, head or power consumption when speed or wheel diameters are changed.
Fan Inlets - Air Density vs. Suction Pressure
High suction pressure at a fan inlet decreases the density of air - and should be corrected for proper selection of the fan.
Fans - Capacity Control
How to modulate fans and their capacities.
Fans - Efficiency and Power Consumption
Power consumption and typical efficiencies of fans
Fans - Volume Flow, Pressure Head and Power Consumption vs. Air Temperature and Density
The temperature and density of the air influences on the volume flow, pressure head and power consumption in a fan.
Types of Fans
Axial and propeller fans, centrifugal (radial) fans, mixed flow fans and cross flow fans.
Types of Fans - Capacity Ranges
Centrifugal, axial and propeller fans and their capacity ranges.
