(particles per cubic foot air)
In a clean room rated as "Class 10000" there may not exists more than 10000 particles larger than 0.5 microns in a cubic foot of air.
Classes and their Typical Uses
Federal Standard 209 E uses metric units and the classes are defined as:
Class | Maximum Number of Particles in Air (particles per volume unit) | ||||||||||
Particle Size | |||||||||||
0.1 μm | 0.2 μm | 0.3 μm | 0.5 μm | 5 μm | |||||||
SI | English | (m3) | (ft3) | (m3) | (ft3) | (m3) | (ft3) | (m3) | (ft3) | (m3) | (ft3) |
M 1 | 350 | 9.91 | 75.7 | 2.14 | 30.9 | 0.875 | 10.0 | 0.283 | |||
M 1.5 | 1 | 1240 | 35.0 | 265 | 7.50 | 106 | 3.00 | 35.3 | 1.00 | ||
M 2 | 3500 | 99.1 | 757 | 21.4 | 309 | 8.75 | 100 | 2.83 | |||
M 2.5 | 10 | 12400 | 350 | 2650 | 75.0 | 1060 | 30.0 | 353 | 10.0 | ||
M 3 | 35000 | 991 | 7570 | 214 | 3090 | 87.5 | 1000 | 28.3 | |||
M 3.5 | 100 | 26500 | 750 | 10600 | 300 | 3530 | 100 | ||||
M 4 | 75700 | 2140 | 30900 | 875 | 10000 | 283 | |||||
M 4.5 | 1000 | 35300 | 1000 | 247 | 7.00 | ||||||
M 5 | 100000 | 2830 | 618 | 17.5 | |||||||
M 5.5 | 10000 | 353000 | 10000 | 2470 | 70.0 | ||||||
M 6 | 1000000 | 28300 | 6180 | 175 | |||||||
M 6.5 | 100000 | 3350000 | 100000 | 24700 | 700 | ||||||
M 7 | 10000000 | 283000 | 61800 | 1750 |
Note! Federal Standard 209E is canceled and superseded by International Organization for Standardization (ISO) Standards - International Standards for Clean Rooms and associated controlled environments, ISO 14644.
Clean room class limits according ISO Standard 14644-1.
Strainers and filters - mesh size vs. particle diameter opening size.
The size of dust particles, pollen, bacteria, virus and many more.
ppm - or parts per million - is commonly used as a unit of concentration.
Some commonly used ventilation principles - short cut, mixed air, displacement and piston principle.
