Ventilation Principles
Ventilation systems may be classified according their ability to supply and withdraw air from the rooms ventilated. It is common to differentiate between the
- short cut principle
- mixed principle
- displacement principle
- piston principle
The Short Cut Principle
The ventilation system is "short cut" when the make up air is withdrawn from the room before it has been in the people operating zones.
A "short cut" will reduce the efficiency of the ventilation system, has no mission, and is in general avoided.
The Mixed Principle
With a ventilation system based on the mixed principle, make up air is supplied to the room with high speed, and/or local fans are used to mix the air in the room to an homogenous mass.
The mixed principle is suited for ventilation, cooling and heating systems
- where homogeneous temperatures in the room are required
- where homogeneous pollution concentrations in the room are required
The Displacement Principle
With the displacement principle heat and pollution is transferred from the residence zone close to the floor - to the ceiling where it's evacuated through the outlet system.
Make up air is supplied with low velocity very close to the floor. The supply air is normally colder than the average air in the residence zone. The evacuated air close to the ceiling is warmer than the average air in the residence zone.
Activities in the room, people and machines, creates convective air flows from the floor to the ceiling:
- heat and pollutions are transferred out of the residence zone
- heat (lights) supplied under the ceiling have limited influence on the temperatures in the room
- the cooling temperatures of the air supplies are limited to some degrees under the temperature in the residence zone
- the pollution concentration in the residence zone is limited
The displacement ventilation system is suited for ventilation and cooling systems. The system is not suited for heating.
The Piston Principle
In a ventilation system based on the piston principle the supply air moves through the rooms like a "piston".
The piston principle can be regarded as an extreme variant of the displacement system with a minimum of turbulence in the air flow passing through the room.
- used in special applications - like clean rooms, operating theaters etc.
Note! To keep the flow "laminar" and stable the air velocity through the room should not be below 0.25 m/s, which requires relatively large volume flows.
• Ventilation
Clean Rooms - Federal Standard 209
Clean rooms virtually free of contaminants like dust or bacteria.
Comfort Environments - Selecting Ventilation System
A quick selection guide of ventilation system in comfort environments.
Ventilation Efficiency
The efficiency of a ventilation system may be related to temperature and/or pollution concentrations.
