Chimneys and Fireplace Sizing
Chimneys can be separated in two main categories:
  • metal
  • masonry
Prefab or Metal Chimneys
Prefab or metal chimneys, class A and double or triple walls are usually found in three diameters. Each diameter has a specific usable area, which is also called it's cross section.
The capacity of a chimney to remove smoke and/or energy (BTU's) from an appliance is directly related to the cross section area.
Chimneys - Prefab or Metal
Chimney SizeCommon Venting Uses
Inside diameter
(inches)
Inside Area
(square inches)
6 28.3 Stoves, Central Heaters
7 38.5 Stoves, Central Heaters
8 50.3 Stoves, Small Fireplaces, Central Heaters
10 78.6 Stoves, Fireplaces, Central Heaters
12 113 Fireplaces, Central Heaters
Masonry Flues
Masonry Flues
Flue SizeCommon Venting Uses
Outside Diameter
(inches)
Inside Area
(square inches)
7 1/2 X 7 1/2 31 Stoves, Central Heaters
8 1/2 x 8 1/2 41 Stoves, Central Heaters
8 1/2 X 13 70 Stoves, Fireplaces, Central Heaters
13 X 13 99 Fireplaces
13 X 18 156 Fireplaces
Combustion
Heating Systems
Chimney Sizing
Calculate chimney draft and required chimney area - online calculator.
Chimney's Explosion Doors
Recommended size of explosion doors or draught stabilizers in oil fired installations.
Chimney's Size vs. Boiler Power
The size of chimney vs. boiler's heat load.
Chimneys - Roof Termination
Chimneys and single wall vents roof termination.
Fuel Oil Burners
Pot types, gun types and rotary types fuel burners.
Natural Draft - Air Flow Volume and Velocity
Air flow - volume and velocity - due to stack or flue effect caused by indoor hot and outdoor cold temperature difference.
