Chimney's Size vs. Boiler Power
- 1 kW = 3412 Btu/h
Required chimney area vs. boiler heat load:
Boiler Capacity | Required Chimney Area | ||
kW | Btu/h | cm2 | in2 |
15 | 51000 | 115 | 18 |
23 | 78000 | 150 | 23 |
35 | 119000 | 200 | 31 |
46 | 157000 | 250 | 39 |
58 | 198000 | 300 | 47 |
70 | 239000 | 350 | 54 |
81 | 276000 | 400 | 62 |
93 | 317000 | 450 | 70 |
104 | 355000 | 500 | 78 |
116 | 396000 | 550 | 85 |
Remember, always check local authorities before final design.
• Combustion
Chimney Sizing
Calculate chimney draft and required chimney area - online calculator.
Chimneys - Roof Termination
Chimneys and single wall vents roof termination.
Chimneys and Fireplace Sizing
Chimneys and fireplaces for stoves burning wood or coal as fuel.
Natural Draft - Air Flow Volume and Velocity
Air flow - volume and velocity - due to stack or flue effect caused by indoor hot and outdoor cold temperature difference.
